Results 1 to 9 of 9
    Mass.
    Default Identify Barn Find Formula Ford
    Need help identifying classic barn find. No tag, log book or paperwork.
    Thanks in advance!
    Larry
ID:	98096   Click image for larger version.
ID:	98097   Click image for larger version.
    I'm guessing it's a Hawke but I haven't found an exact match yet....
    West Union, IL USA
    Liked: 319
    Default guessing here
    Hawke DL9?
    Parallel links in bottom of rear suspension was my clue but this is still just a guess.
    Hawke DL9?
    Yeah, that's what it looks like, with the dash hoop being added later.
    London
    Liked: 40
    Yep, Hawke DL9
    Mississauga, Ontario
    Liked: 902
    Hawke DL9?
    Agree - looks a LOT like a DL9!
    Liked: 909
    Check with Keith Averill, IIRC he had a Hawke FF back in the day. Not certain what model however
    Sydney, Australia
    Liked: 146
    Sure looks like my Hawke DL11, even down to the Roland valve cover.
    The front lower rack mounts, show a longer stud that is used on mine to attach the front radiator.
    The DL9 used side radiators, DL11 front.
    London
    Liked: 15
    Looks like it still has the original roll hoop. That should have SCCA registration number. Should at least give you a place and approximate date.
