One common issue that causes wheels to come loose is interference between the wheel and the radius at the base of the hub center snout, usually because the radius from the wheel center hole to the mounting face is not large enough. When this happens, the centerlock nut is actually clamping the wheel against that radius instead of the hub face, allowing the wheel to wiggle slightly, which in turn loosens the nut.
