Results 1 to 26 of 26
Thread: 1984 Reynard
    so cal
    Liked: 6
    Default 1984 Reynard
    SOLD
    Own a Piece of History, this car is previously owned and raced by the most famous “APEXer” of all time. The car has completed a full ground up restoration and then run four events. It had virtually every part on it either remade or refurbished, it tips the scales w/o fuel just under 1000lbs. The engine is Butler built that was refreshed with Ivey valve springs, new followers and uprated scca spec cam (set retarded 3dg). The gearbox was rebuilt with a new case and has the annular style hydraulic slave. Fuel cell was re foamed, all uprights have new brgs, steering rack is refurbished with new bushings, New Swift Style dash Panel, all new gauges, New Fire Marshall fire system(will need recert in Feb), All new Alum Skins with bonded Floor, new Saldana Radiators, new water pipes, new Headrest with SFI foam, headers and collector refurbished with new Stainless tail pipe. Bodywork is stripped down to the gelcoat then refurbished, new nose from Crowe composites, Averill front wings and Vd rear wing. Diffuser is a modified unit from an 88 Reynard, I could go on and on but you get the idea.
    $18500
    Spares include
    1 Polycarbonate Windscreen
    5 sets Front wing Plates
    24 gear sets total(4 in car)
    1 front rocker
    1 frt wishbone
    2 frt spindles
    1 frt hub
    2 rear rocker
    2 camber links rear
    1 Rear radius rod
    1 set of shear plates(front)
    1 set rear wing mtg plates
    3 sets of Oz wheels
    2 sets wheel nuts with hats
    4 sets springs 1100lb, 1000lb, 900lb, 800lb (2 sets in car)
    1 Lower Rear wing plane (wrinkled but usable)
    1 Set Hawk Brake Pads Front
    1 Set Pagid Front Pads
    2 Sets Pads Rear
    1 Nelson Iron Head (needs Cam and Refresh)
    1 junkyard block
    misc items like Jets, Oil Filters, coil, Ignition Box(used) plus other bits.
    Contributing Member Jtovo's Avatar
    Chicago, IL
    Liked: 78
    I will bite. Who owned it?
    Liked: 804
    Quote Originally Posted by Jtovo View Post
    my guess: the most famous “APEXer” of all time
    Liked: 3787
    My guess: Mark Hathaway from Atlanta
    Before that it was raced out of Plover Wisconsin. (Rock)
    Chicago, IL
    Liked: 78
    I was thinking it might have been yours, seeing as you and Dave are the most famous APEXer's.
    Lafayette INdiana
    Liked: 295
    It looks very nice.
    Liked: 3787
    Joe, You must be thinking about this car...
    pre Purple Frog 1999 LOL
    You gave me the extended mirrors for the tow vehicle....
    so cal
    Liked: 6
    more pics
    Liked: 3787
    I think it looked like this in 2002...
    early Purple Frog
    I don't think it has ever looked as nice as it looks now; not even when it first left England.
    In 1998 I think I was working at the Daytona 24. During the night I was chatting with a suspension engineer on a big name race team (name withheld to protect the innocent). I said I was thinking about getting into FC. He told me the best car to start with was an 84 Reynard. Saying it was the most balanced easiest car to learn in. I took him at his word. I think it still holds true.
    so cal
    Liked: 6
    Thank you PF, a lot of blood, sweat and tears went into this build
    early Purple Frog
  14. #11
    Liked: 3787
    I last saw Jerimiah in a warehouse in Atlanta around 2007... It was totally clapped out and rough.
    The rebuild you have done is incredible. A work of art.
    Could never use the "V" brace above the pedals, my feet were too big.
    I added the 1/4" steel webs on the front of the front uprights. As the tires and brakes got better over the years the older upright design tended to crack. No problem after adding the webs.
  15. #12
    so cal
    Liked: 6
    PF countless hrs were spent on details most won’t appreciate but being a former top level professional race mechanic it was necessary work to bring the car back to the quality level I am accustomed to. V brace, yes it pays to have small feet. Notice the rt front upright has your web, the lf I added a gusset as seen in the pics. Mark must’ve had a bit of a shunt...I have the webbed upright But it is needing a little attention.
    thank you for the kind words, the new owner will be very happy with this car
  16. #13
    Liked: 1489
    Has to be one of the most spectacular FCs ever built. Really.
    Someone in SoCal please buy it and stay local!
  17. #14
    Fresno, CA
    Liked: 39
    Default 1984 Reynard for sale
    I saw this car at Buttonwillow and it is every bit as nice as it looks in the pictures. I'd say the price is pretty fair and I'm tight with money!
    Tom
  19. #15
    oak hills, california
    Default still for sale ?
    Hi is this car still for sale ? text 562-761-1999 thanks!
    so cal
    Liked: 6
    Car is currently off the market
  21. #17
    so cal
    Liked: 6
    Car is Back up for Sale, Since last summer the following upgrades were added....
    All new Aurora rodends
    URS Rear Hub Kits Installed
    Fast Forward Axles and Cv
    New Fuelsafe Fuel Cell with Electric Fuel Pump and Custom Pickup to get every oz of fuel out
    Head Refreshed with New Exhaust Valves and Springs.
    This car runs well and is dialed in for the next owner.
    Car with one set of wheels $14500
    Car with all listed $18500
    Spares sold separately once car is sold
  22. #18
    Member racerjon's Avatar
    Waterford, Michigan
    Liked: 14
    Default Your car
    I’m interested but your mailbox is full......
  23. #19
    so cal
    Liked: 6
    Quote Originally Posted by racerjon View Post
    Mailbox is now available
  24. #20
    Glendale, Arizona
    Liked: 502
    Not Hathaway's car
  25. #21
    so cal
    Liked: 6
    it looked like this once upon a time
  26. #22
    Default is the car still available?
    HI.. it you still have it... let me know .. if I recall you are in Orange County... So about 1.5 HR away.. 562-761-1999 rick
  27. #23
    so cal
    Liked: 6
    Quote Originally Posted by us395 View Post
    Car is still available. Correct south oc
  28. #24
    so cal
    Liked: 6
    Pics
  29. #25
    so cal
    Liked: 6
    Deposit accepted
  30. #26
    so cal
    Liked: 6
    Reynard specific spares are up for grabs
