Hello All,
I'm just going through my car and checking all the boxes to make sure the car is right, one of the things was the clutch slave cylinder bracket has 2 new holes to reinstall the clutch slave cylinder well that means that the adjustable rod is max out. So I said can I reposition the clutch lever on the out side of the Mk9 and then noticed the lever was bent and then rewelded back on, does only one have a picture of a new one that I can reference from and can you get new ones in case this one is bent.
thank you for any info
Ben
