Ohlins 44 series shocks 4 way
I have a set of 4 shocks, ends can be changed to make for different lengths.
2 are 11 7/8" extended / 8 7/8 closed
2 are 14.5" extended / 11 5/8 closed
they have adjustments for :
Low-speed compression damping adjuster
Low-speed rebound damping adjuster
Reservoir compression damping adjuster
High Speed Compression damping adjustment
travel is 3.0 inches for all of the shocks and have a 6 3/4" body (measured from center hole are mount to end of body)
and
$2,600.00
lorenz(at)teamlorenz.com
thanks
Chris Lorenz
