Results 1 to 8 of 8
    Maine
    Default Another Puck Question (canister type)
    Hi All:
    With the canister style the puck is mounted between two aluminum washers which are held together by a bolt and nut. How tight should the initial compression on the puck be? It seems to me that if it's too tight part of the suspension "travel" will be lost. Thoughts?
    Liked: 239
    Quote Originally Posted by Frank06 View Post
    Hi All:
    For Red Devil shocks, which have the puck turned on its side, there is compression but not too much. It's not adjustable so I never measured it. I suppose that some people may be able to compress them by hand for assembly, but I always used a vise or c-clamp.
    I had a KBS for a short time and don't remember those being adjustable either.
    Cory
    Maine
    Thanks Cory. I've always been curious what that setup looked like: you wouldn't happen to have a picture, would you?
    Senior Member lance3556's Avatar
    Aloha, Oregon
    I will be rebuilding my canisters this weekend, I will take some photos to show the KBS style.
    Aloha, Oregon
ID:	95046   Click image for larger version.
ID:	95047   Click image for larger version.
    Maine
    That certainly looks interesting... can you describe the operation please? Is the puck still compressed during suspension motion?
    Aloha, Oregon
    yes. I apply a small amount of preload so at full droop, the cone is still applying some pressure to the rubber puck. As the suspension travels up, the cone deforms the puck, this compression then will provide rebound when the suspension lowers. I also have friction washers on the bell crank so the rebound is controlled to some degree.
    Maine
    For fun, here's what one of mine looked like. The rubber was kind of beat up.
Name:	F500 Canister.jpg
ID:	95099   Click image for larger version.
Name:	F500 Inside Canister.jpg
