Results 1 to 24 of 24
    Chatham Center, New York
    Liked: 969
    Default 2021 FRP Schedule
    2021 Formula Race Promotions Schedule
    April 1-3 Carolina Motorsport Park
    April 30-May 2 Mid-Ohio Sports Car Course - Tentative
    May 21-23 Barber Motorsports Park
    June 18-20 Pittsburgh International Race Complex
    July 30-Aug 1 Road America
    August 20-22 Summit Point Motorsports Park
    September 10-12 Autobahn Country Club
    October 15-17 Pittsburg International Race Complex
    Liked: 822
    Nice to see more western dates!
    Liked: 1379
    Western? About 60% of the county is West of the most western venue listed.
    By that measure the Mississippi is the western border.
    Liked: 404
    As my ex-wife used to say, you have the gift of the bleeding obvious.
    Peter Olivola
    (polivola@gmail.com)
    Liked: 822
    "western" being a relative term in this case.
  9. #6
    Columbus, OH
    Liked: 482
    When will MidOhio be set? This is a change, right? I was looking forward to July 4th at MidOhio..,
    Liked: 969
    Its listed as tentative until the owners of Mid Ohio certify the overall MO schedule- we go though this every year. Our date change is because Indycar took our traditional July date because of the Olympics and TV. Its called dominos.
    Columbus, OH
    Liked: 482
    10-4. I kinda figured...having been part of a car club that has similarly been pushed around there...
    THX
    near Athens, GA
    Liked: 955
    Also interesting that Road Atlanta is NOT on the schedule....
    Liked: 3542
    Default Interesting saga on the way home from RA
    Speaking of Road Atlanta -
    Had an interesting experience with the van (1974 Chevy G30) on the way home from Road Atlanta Nov 1 - brake pedal suddenly went almost to the floor and the large, bright brake warning light came on. Luckily we got stopped OK, and the brake pedal pumped back up and felt normal. Brake fluid level looked OK, too. Brakes worked fine the rest of the way home with the trailer on the back even though the light stayed on. When we got home and detached the trailer, the rear brakes immediately started locking up on the gravel driveway and the fronts appeared to be not working. So the fact that the rear brakes are so large (1-ton axle and huge drums) saved our butts. I haven't had the time to diagnose further yet - too much other stuff going on. Probably a line leak - almost all the brake stuff, except for master cylinder and rear wheel cylinders, is as old as the van - 46 years. There is almost no rust anywhere, so it's likely one of the rubber lines.
    Have I mentioned that in anything that matters, I am VERY lucky?
    I posted a new thread on this in the Trailering and Towing section...
    Liked: 884
    IIRC, a few years ago Atlanta dropped off the schedule;
    there was much wailing, so it was reinstated the next season, and was subsequently one of the lowest turnouts ...
    ... at a criminally expensive track to rent.
    Correct me if I'm wrong, but I believe that's the gist of it.
  17. #12
    near Athens, GA
    Liked: 955
    Didn't they race there just a couple of weeks ago?
  18. #13
    Liked: 969
    yup...."at a criminally expensive track to rent" with mediocre turnout. I still love the track, but...
  19. #14
    Liked: 3542
    It's a shame, IMO, since I love racing at Road Atlanta (and at Watkins Glen), but FRP has got to at least break even to stay viable and provide us with a great series to race in. So I get it.
  20. The following 4 users liked this post:
  21. #15
    Deep River, Ontario, Canada
    Liked: 132
    Default GM brake lines
    Dave, I have owned 96 and 97 GM 3500 duallies. BOTH blew hard brake lines while stationary. One reversing onto the 'pin' the other when running the truck with the rear raised wheels off the ground searching for a possible bent rim. Different locations on the truck but both at plastic clips to the frame.
    Scared the **** out of me thinking about what if's?
    I note you did not have fluid loss which clouds your issue. I have heard of the pig tail section below the master letting go gradually.
    The 97 now has copper nickel lines front to back.
    KR
  22. #16
    Maineville
    Liked: 105
    Default Brake Lines and Brake Designs
    On my 1999 Ford F250 the lines rusted through after 6 years and in their infinite wisdom they decided to go with a single reservoir for brakes versus the old design where front and back brakes had distinct reservoirs. Fortunately when I lost all brakes I was able to swerve into berm versus smashing a family in a mini van. I ran all stainless lines front and rear. Someone please tell me the rationale for the change in master cylinders and how that got by the safety gods.
  23. #17
    Liked: 3542
    When I get the van on stands and wheels off to do my annual maintenance (rotate tires, grease 22 fittings, lube the leaf springs, change oil, oil filter, AF, etc.), I'm sure I'll be able to spot the failure cause. I'm guessing one of the front rubber brake lines gave up the ghost after 46 years - the fluid was down in one reservoir section slightly from totally full, but if I hadn't had the issue I would have thought nothing of it. We had done several very sharp turns (lock to lock in both directions) in the motel parking lot just before and the extreme flexing in a cold morning was likely the last straw.
  24. #18
    Liked: 307
    Default Rubber lines
    Had a motorhome about same vintage as your van. P30 chassis which is similar to GM 3500 stuff. Well had strange brake issue and turned out to be one of the front rubber line. Nothing you could see from the outside. But was failing inside and would restrict flow. Could explain you failure. You pushed down on the brake and fluid went to front brake but was restricted from returning due to internal failure. You were able to pump up as pressure from the pedal is more then the return pressure.
    Just a thought
    Ed
  25. #19
    Liked: 955
    Have had the same internal blockage on GM flex lines 3 times on two different vehicles.
    Tough to figure out until you try to bleed the side that is not getting any brakes and no matter what you do no fluid will come out.
    Researching it found out that it is not all that uncommon on GM vehicles.
  26. #20
    Liked: 3542
    Does sound like a line failure might be the cause - whether it is a blockage, or one sprung a leak, we'll find out when I get it in the air and I look more intensely for issues.
  27. #21
    Liked: 3542
    Just a thought
    Ed
    What may go against this diagnosis is that the brakes never pulled to one side during brake application or driving w/o brake application. So something, IMO, let a small volume of fluid out of the front system w/o restriction. If that is the case, something sprung a leak - line, caliper, etc.
  28. #22
    Commerce Twp Mi
    Default Brake failure
    Dave,
    I would suspect your master cyl is going bad. The missing fluid is probably in or around the booster and/or the seals are failing.
    David
  29. #23
    Liked: 3542
    Quote Originally Posted by lapsturbo7 View Post
    Dave,
    David
    That's a possibility, but multiple brake applications (VA to home - Bath, OH) after the initial incident did not result in another low pedal or more (any) fluid loss. So I will investigate every possibility until I find the culprit. Haven't had time yet to diagnose.
  30. #24
    Liked: 3542
    Default Update
    Thanks to everyone who responded on my van's brake issue - I think those of you who thought the master cylinder had malfunctioned may have been correct, but...
    The latest thinking is that it was the delay/proportioning/brake -failure-signal valve that caused the issue. The question remains, though - WHY did that give the initial VERY low pedal ?
    I started a new thread in the Trailering and Towing section and I will post further updates there. Link to that thread:
    https://www.apexspeed.com/forums/sho...G30-van-update
