Results 1 to 10 of 10
    Contributing Member jemartin144's Avatar
    chicago, illinois
    Default GSXR 600 year compatibility
    I am running 2006-07 GSXR 600 engines currently and I am wondering what the compatibility to newer engines would be. The 06-07 engines seem to be getting harder to find so if i could move to 08-09 or newer without much work that would be good to know.
    I believe the oil pans and headers should swap fine.
    The ECUs look the same so maybe i could just swap out the right year's ecu? i havent looked at a wiring diagram to see if the pinouts are different.
    Anything else with the electrical system that wouldnt be interchangeable?
    Are the mounting points/physical dimensions the same? just looking at pictures they look almost the exact same.
    thank you,
    Liked: 239
    Jason,
    Someone who knows these engines (like Clint) may answer here, but Leon and Jeremy would definitely know the answer.
    Cory
    I am certain that cal Stewart knows this answer and i will ask him tomorrow!
    Lapeer, MI
    Liked: 91
    There are 3 motor generations commonly used in our class
    06/07 Silver cylinder head, airbox mounts to throttle bodies with hose clamps
    08/09 Black cylinder head, airbox bolts into throttle bodies, different Cam shafts from prev generation
    2011-2015 Black cylinder head, updates to throttle bodies from 08/09, same airbox mounting, updated spark plug coils
    -The engine mounting points are exactly the same from 2006 thru 2015
    -The same oil pan and headers will work for all those years
    -The throttle bodies are a different design after 06/07 generation
    -The ECU's look the same but have different mapping thru the years
    -The wiring harness is slightly different for each generation, but may still work
    covington ga
    Liked: 72
    Quote Originally Posted by TDI PILOT View Post
    The wiring harness,ecu,throttle bodies and air box will be different. The best thing to do is to buy a "car kit" off of ebay like the in this link. https://www.ebay.com/itm/2013-11-19-...0AAOSwjyhe5F5P
    Don't buy one with less than 3000 miles on it. If you do you'll likely blow it up due to the bearings being a bit on the tight side.
    Listen to Clint.
    Pennsylvania
    Default Need Help
    I have a 2013 GSXR 600 that my son was working on before he passed I would like to finish it for him but don't know what years I can use as a doner. Any help would be appreciated.
    Liked: 1156
    So very sorry you lost your son, and hope you can finish this project as your tribute.
    Indianapolis, In
    Liked: 32
    Default years
    Quote Originally Posted by Mikegsxr600 View Post
    According to Wikipedia 2011-2020 should be interchangeable.
    Condolences on the loss of your son!
    Good luck!
    Pennsylvania
    Quote Originally Posted by allof6 View Post
    Good luck!
    Thank You
