Maybe this has been discussed before but my searches have not located it.
So, I have 2 different engines I'm rebuilding. And 2 different styles of head draining.
Engine 1 - External drain off the rear right corner down to a tube in the block placing the oil into the bottom of the pan.
Rear original drain blocked. Front original drain restricted.
Engine 2 - NO external drain. Both original drains fully open.
Both engines have restricted supply.
In discussing with engine builders, the advise I've been given is as such:
- External drain IS needed
- Original drains should be completely open - not blocked.
The engine that currently does not have an external drain also does not have a boss in the block - like the engine that does.
(Different castings). The suggestion was to tap the pan and drain it directly to the pan.
So, here are my questions.
Why can't I drain directly to the tank - into the port currently used for the vent tube? It's all gravity.
Do you use both drain styles together?
Is there a reason not to (other than the HP loss of oil onto the crank)?
