Results 1 to 16 of 16
    Pipersville, Pennsylvania
    Default FSV clutch disc/input shaft spline
    Need a 200mm. 4 puck solid hub clutch disc with an approx. 18mm. [ .70"] O.D. 24 teeth spline to mach the input [ clutch] shaft in my Hewland MK8 gear box. NO one [ not even Hewland Classic-they denied they made it ] can tell me where it came from! This was the original disc installed in 1978. I have tried ALL the suppliers and mfgr's. Could this be 3/4" nominal? Any ideas? Car is 1978 Wheeler FSV S/N 010 Thanks for your help Ted Klaus-greyeagles@msn.com
    Liked: 1489
    stock vw
    stock vw
    Sorry- it is NOT stock VW! Stock VW is 13/16 [.81"] - There are many 24 teeth splines from 1.3" to 13/16 but after a month of searching I have found NO .7" [18mm.] spline! Anyone else have a guess?Ted K.
    Fallen Friend
    Pensacola, Florida
    Liked: 168
    Default reuse hub?
    Why not use old hub with new driven plate? I've done that a few times when splined hubs were backordered. Talk with clutch folks.
    Bob L.
    Houston, Texas
    Liked: 25
    Default Supervee Hewland input shaft
    Ted,
    Did you solve the problem? I think I have the same situation.
    JR
    Lincoln NE
    Liked: 85
    I had the same issue when I bought my Royale, years ago. Sticks in my head that it might be a disk from a VW "Thing", but we are talking 25 years ago. I finally just changed the input shaft to standard VW.
    Houston, Texas
    Liked: 25
    Thanks - mine is also a Royale (RP14)' What vendor did you use for the new shaft?
    Lee Williams of WRD may have some info on this.
    http://www.willrace.com/
    Lincoln NE
    Liked: 85
    no idea where it came from it was used may have even been in a box that came with the car--also a RP-14
    Houston, Texas
    Liked: 25
    Used would be OK.
    Lincoln NE
    Liked: 85
    after a bit more thought about it, it's possible I used that part from a regular VW box---worth checking
    Default Hewland problem input shaft ?
    I can make these type of shafts and regularly do it. I have many hobs and hobing equipent for this purpose. I have supplied Pegasus, Taylor, Lee at WRD and others for years, 1 or two at a time. Heat treated material 4340 or 4130 I need the old shaft for dimensions and a clutch disc or hub that fits the odd spline. CMW Enterprises, Inc www.dogrings.com Wayne 760-942-9170 Calif. Call for details.
  16. #13
    Houston, Texas
    Liked: 25
    I removed my input shaft this AM, and it has a number of hc23910 etched in it.
  17. #14
    Liked: 909
    If it is air cooled almost certain to be a stock VW spline.
    Liked: 909
    SACHS used to make racing discs for them.
  19. #16
    Houston, Texas
    Liked: 25
    You are correct - the stock VW spline is what I am after. The rest of my shaft is proper. Wayne @ CMW is going to build one for me.
