Originally Posted by
Raceworks
In general the Honda's like more air, not just to the rads but around the intake manifold. Fuel injected motors don't atomize the fuel till the intake port in the head so you don't get the cooling effect on the intake manifold like you do with a carburetor.
In general, you may need to run some extra ducting or cut some vents in the sidepods with the Honda motors. Adding some extra heat shielding helps, especially where the crossover pipes between the radiators pass near each other.
If you weren't running an oil cooler before, get one.
Oh, and of they're still sending those little XRP mesh fuel filters with the conversion kits get rid of them and put something with a good paper element in them. I've seen the XRP filters clog up and lean the engines out, causing a variety of issues including overheating.
