Once again being a glutton for punishment, I decided to rebuild all 4 calipers. I found that 2 had 2 cross feed seals and 2 had only one hole. Is one better then the other? Should I mount them the same on the same axle or does it not matter?. they were not mounted the same originally. Also one piston had a much thinner wall then the others, any reason?
After cleaning the pistons and polishing with 400 grit, still had some pits, should these be replaced? Pits arent deep or very large.
Finally, any pros or cons to using the outer seals or not?
TIA
John
