lotus twin cam---------large valve, "L' block, steel crank stamped "laystal oct 68", alum cast head with cover, "L1" cams, no carbs or distributor, there are 2 sets of used pistons and rods, only one set goes with this you choose, looks as though both sets have been ground and polished ,couple small boxes with smaller parts ie buckets,nuts and bolts, chain, can probably find a dry sump to fit
$4500 usd
