Results 1 to 5 of 5
    Wetmore, CO
    Liked: 110
    Default Wilwood Slave Cyl
    Anyone know the stock replacement for a wilwood slave cyl on a Stohr FB? There are no markings on it to define the specs. Is it this?
    https://www.wilwood.com/MasterCylind...temno=260-1333
    Or
    looks more like this:
    https://www.amazon.com/Wilwood-260-1...SIN=B002G35NV0
    Cj
    Denver, CO
    Liked: 80
    Courtney,
    You may want to clarify - the links you sent appear to be clutch slave cylinders - do you have an 05-06 Suzuki engine? All the 07-08 Suzukis have built-in hydraulic slave cylinders.
    -Jake
    Wetmore, CO
    Liked: 110
    Quote Originally Posted by JakeL View Post
    Courtney,
    -Jake
    Thanks Jake,
    I was looking for one for the 05-06 GSXR 1000. I think Stohr is hooking me up with one but it would be nice to document the specific model! Lots of variables but no numbers on the existing part to cross reference. Other than wilwood.
    I do have an 06 engine with a built in but no clue of where/why/how it came from... 07 engine? Not sure if they are cross functional.
    Any input would be appreciated!
    Cj
    Hi Courney, the Wilwood 260-1333 slave on Amazon is the correct one to convert an '05-'06 GSXR from the cable actuator. If your have an '08-style clutch cover that eliminates the need for the external one, and this was a common upgrade, both from Stohr and as a retrofit by FB owners.
    Cheers, Stan
    Wetmore, CO
    Liked: 110
    Cheers, Stan
    Thanks Stan,
    We will continue as planned (ordering one from you) as we discussed tonight earlier!
    So, my other engine may have an 08 cover on it. Good to know!
    Thx!
    Cj
