Torsion bar spacers some steel, some aluminum, some welded bronze $10 each
Offset link pin bushings used but not worn out $ 10 each purpose built $5 each modified production bushings
Center adjuster part $5
Vee modified pitman arms $10 each
Vee modified and re-inforced spindles $30 set
Lower trailing arms Shock bolts modified in some way. $10 each
Steering Boxes other wise good. Input shaft modified and Pitman arm welded and modified $20 ach
S
