This racecar is all set to go into the 50th event at Summit Point. Fresh Engine, Clutch, Ring & Pinion, Shift Dogs, Linkage, Gauges, Radiator, Body Work! You name it and it has been done and done with TLC. Asking $17,750.00
PM or call 914-576-1916 Racecar is located in Hagerstown, MD. 45 minutes from Summit Point Track
