Results 1 to 13 of 13
Thread: More FV Parts
    Liked: 4362
    Default More FV Parts
    Brake shoes. $50 Sold
    Two very good FV anti-roll bars. 3/4 never used Sold.. 1/2" lightly used. $75 each.
    Buy both for $150 and I will include 1 2/3 genuine VW spring packs.
    From my travelling spares kit.
    1 LS spindle/kingpin assembly. Steering arm removed to use with bolt-on arms. $70
    Lower front suspension arm. $40
    I have dozens of arms (upper and lower) if anyone needs more. set of 4 $100
    2 rear drums. Used but perfect for spares.
    Both German, one smoothie (8.331" ID), one ribbed (8.366" ID)
    $35 each Sold
    From my travelling spares kit, Used TRW steering box. $50 Sold
    From my travelling spares kit. Used rear axle tube assembly.
    Good bell, good flange, good boot, outer bearing. Ready to use. $75. Sale Pending
    From my travelling spares kit. Clean , ready-to-use oil cooler manifold assembly.
    Return port plugged and bypass port installed. Could be undone. Thick cooler.
    Includes used seals, hardware, even 12mm head nut for inside. $300 Reduction Now $250.
    New VW oil cooler 2" version (no manifold) $50
    New BRP 500 Clutch Slave (pull) Cylinder $60
    Also from my travelling spares.sales kit.
    Excellent condition brake drums.
    Brand new front drum (8.280" ID) $60
    Almost new front drum (8.281" ID) with used bearings installed $70
    Very good rear drum (8.270" ID) $50
    Three for $150
    Also, 1 absolutely cherry rear backing plate.
    I thought it was new, but has some pitting under paint so it must have been refurbished. $40.
    Also 7 good use rear axles. $40 each, $75/pr 2 Sold
    Bench top VW engine stand (2) $35 each
    Will consider trades involving multi-layer driver suit (6'-200lbs)
    greg13rice-at-hotmail.com
    Will package in groups for discount.
    Shipping extra.
    Burr Ridge, Illinois
    Liked: 301
    PM sent.
    Elkhorn, WI
    Default Parts
    PM Sent
    Liked: 4362
    Still for sale.
    Massachusetts
    Hi, Looking for spindles or bolt on arms. Thanks
    Liked: 4362
    I will be at Mid-Ohio this weekend and have a couple hundred lbs of surplus VW & FV parts to sell. No reasonable offer will be refused.
    I will be with RCFFS, blue #27, and black #07, and will have a table set up.. Enjoy the weekend!
    Liked: 4362
    Default VW Oil Cooler and Manifold
    SOLD.
    Liked: 4362
    Still have the complete oil cooler assembly above.
    Found another new 3/4" front swaybar ...... $75.
    Used 1/2" swaybar from top post, great for rain .....$60.
    All Sold!
    Greg13rice-at- hotmail.com
    Liked: 4362
    Default Penske 11" 8100 Shock
    Most of my FV stuff is gone, but I recently found a shock that I had once used on the Problemchild FST/FV cars.
    8100 with AA/E valving. 11" extended length with 2 3/4" travel.
    $500 Sale pending.
    RiceRacePrep-at-gmail.com
    Liked: 4362
    I am cleaning out the shop of surplus parts. I will load up the back of the pickup truck and bring stuff to the Runoffs. Lots of misc FV, FF, and general race parts. If interested in something, please email me until Thursday morning. Thereafter, you can text me. I will be based at MS49 in the main paved paddock. We will be watching races, so you will need to make arrangements to meet up.
    Most of the FV parts above have been moved out. I still have the VW engine stand.
    I found one "goodie" tucked away that was used on The Shirley MacLane FV. It is a cockpit adjustable hydraulic droop control device. As more knowledgeable FV people know, the rear droop limiter setting is the most important spec for handling. This lets you adjust from the cockpit. This also includes collars to install a booster spring to help fight rear squat. $350 OBO
    See above for my application. It is the top assembly. Common Penske shock and spring is below, mostly hidden by exhaust.
    Watch for other items in my "garage sale" posts in FF and FC threads.
    Member tsiembieda's Avatar
    Waukee, IA
    I'm the current owner of Shirley MacLane FV and was curious on how the droop limiter attaches to the rear suspension? I'm assuming it sits above the shock but not sure from the photo.
    Liked: 4362
    The hydraulic droop limiter just replaces the original limiter, running parallel to the rear shock assembly. I had extended the bellcranks/rockers to allow for the extra size. I have no recollection of specifics, but expect that I trimmed back the rockers when I removed this assembly. It was more than 2 decades ago.
    Liked: 4362
    I pulled 5 boxes of old FV parts out of my shop that I want to get sell off. I will set the stuff out on some tables on Friday afternoon, so if any FV people may want to check it out. I will be based at MS49 which is on the main road to the false grid (about a hundred yards before). If anyone has interest in specific parts please text me and we can meet up. I will arrive Friday am. 716-946-1857
