    Kansas City
    Liked: 110
    Default 01 VanDieman oil level
    Have a new to me 01 VanDieman I'm rebuilding. Next few days will have oil in it but have no notes from the previous owner on oil level in the tank.
    Can anyone tell me the recommended oil level?
    Southeast MI
    Liked: 254
    High enough so the input shaft tube is not visible. Depending on your lines and cooling package it should be somewhere between 4 and 5 qts.
    Kansas City
    Liked: 110
    Default Oil level
    Thank you Bill
    Sounds like down about 3 inches from the top, ballpark.
    St. Charles, Illinois
    Liked: 180
    But make sure you crank with plugs out of it after you fill it to that level. If your oil lines are empty they will suck about a quart of oil and then you will have to refill the tank to the proper level.
