I'm replacing the old worn out Triumph steering rack with a new Titan rack on my Caldwell D9. It is drilled for 1/2" LH threads on the end of the rack and so I'm planning on using rod end based tie rods. The question is do I go with a clevis on the rack ends and what size rod ends on the tie rod? Then out at the Triumph steering arms how do I convert to a rod end to replace the tapered ball joint? I would think there must be adaptors for this.
