LOWER PRICE as of 3/9/2017.
List of Features- Spares – Tools - Details AIM EVO 4 / MyChron 3Dash (all interface cables & software) Separate ON/OFF for display configuring. Serial to USB cable (jumper in place) for MBE ECU to Laptop A/F ratio meter Rebuilt transaxle by Comprent Motor Sports. Absolutely perfect! New ring & pinion New bearings Blueprinted, with all the correct parts New 5th gear, new input shaft & updated differential. Larger actuator. New fuel cell and heat shielding Rebuilt brake calipers Rebuilt master cylinders New brake pads Floating rotors Quick disconnects on Fuel, Clutch & Rear brake lines 3 sets OZ wheels 1 NEW set American Racer slicks-mounted. Chassis set up consistent with the AR tires Re-riveted belly pan (600 lb tension rivets) New Jabrock under tray protection system –front & rear New drive belts – Oil/Water pump & alternator New water pump New coil pack New plug wires Rebuilt & calibrated injectors New throttle position sensor set to correct position New TPS pigtail New spark plugs New relays Re-flashed ECU w/correct interface cable New header gasket Updated axles New tripods New axle stops MK-1 seat New OMP 6-point harness Radiator drain hoses to rear of chassis (very handy) Rebuilt shocks New shock eye bearings
All NEW rod end bearings New flywheel Rebuilt clutch w/ new discs New throw-out bearing Rebuilt slave cylinder New clutch master cylinder New rain light Gurney lip (1/2 inch) on front winglets New dry sump tank screen Log book and inspection up to date- 2016
Spares: New spare nose cone Muffler/Muffler elimination pipe Rear body winglets Ballast weights (48 lbs) Coil Pack Plug wires Relays All drive belts Transmission bits Rebuilt clutch master cylinder 1 set brake pads used @ 50%
Tools: Pinion Nut tool High chassis stands Alignment bars ( MT ) Aux. starter battery cart w/ storage box, pit tools & air tank Front and rear tow hooks installed Tripod service kit – grease tool Transmission shipping container Digital Read Out ctr-ctr Fixture (trick) for A-arm, damper eye & push rod centers. Tire cart (4 tire/wheel) Brake piston wrenches (31.8 & 38 mm) Brake pad spreader tool NEW Longacre scales and levelers
Trailer is available:
Will sell separate or sell as a package.
Trailer is an 18 ft. tandem axle TimberWolf, white in color w/3500 lb axles, refinished interior and exterior, new brakes, new tires, new e-brake battery & fresh wheel bearing service. Tongue mounted spare. Hitch lock. Interior furnishings include closet, workbench, tool cabinet, air compressor, 15 gal fuel storage jugs, e-track and tie downs, remote controlled 2500 lb. loading winch w/ deep cycle battery and charging system, custom loading ramps, tire racks, chassis stabilizers(no motion when towing) and many more features to accommodate the FE. Trailer outside wall mounted canopy with new tarp at 8 by 16 ft.
10,000 lb. Adjustable height Equilizer hitch with sway control. Additional 2” drop 7500 lb. draw bar. Wireless brake controller.
email jstrickler22@gmail. com
Phone 913-663-2001
Can email pictures
Package Price: __________ $34K
FE-117 race car with spares & FE tools:________________________$30K
Trailer with associated equipment: ________$ 5K
