Ok..just watched a video of one of Hamilton's laps in Australia...
spike of 7.8 G and sustained around 6.7......I have no words.....
The average guy passes out at 7 G's.... incredible
Spikes vs sustained is the key here.
For example, an F-16 fighter is computer limited to 9g sustained WITH a flight g-suit, which is all the pilot can take, although aircraft can do more.
I'd be curious to see F1 data traces this year of a longer corner such as at monza.....
Ian....the f16 driver also has a lay down seat that reduces vertical distance from heart to head....I wasn't awestruck by Hammie not passing out as much as I am speechless about the current cars lateral G capability and the drivers ability to function at that level over a race distance...
cart went to texas in -99 or -00 without prior testing.
it didn't take long for drivers to experience tunnel vision, etc
can't remember g #s but they were sustained for most of each lap,
nasa folk were called and said g-suits or not run.
event was canceled.
banking was changed later
oops
Sort of related but does anyone know the max lateral G's that you would expect to see on a well setup Formula Atlantic (in my case a Swift DB4) on a sweeping corner?
The lateral g we see is not the same as the vertical g that pilots see in a race car the blood does not get pulled into your feet.
The situation at texas was more like the pilot situation. Because of the high banks there was a significant g component along the drivers spine for extended periods. That was probably low enough to be countered by the straining technique but i doubt any of them would have had the stamina to do that for the whole race.
Caveat: not a doc, just spent a bunch of flying at hi g (6+) and got my human factors MS (as part of the bargain).
The biggest trade space between fighter aircraft and F1; ejection from aircraft - not F1 (just yet - but, just a twisted aside - why not at the salt flats?). Spine upright = less impact injury (spinal compression) on ejection. As the F1 pilot is not so equipped - a very reclined seating position can be had for lower aero cross-section and vertical g loading. Fighters (pre-Generation 5) rarely experienced horizontal g - always loaded up through the vertical axis - not in a slip around or through it.
Getting the feet up above the thighs and butt prevents pooling, but can go momentarily numb under load. Again, most useful for hi g banked corners - not hi g lateral turning.
There were remarks about the new cars performance at Barcelona, and the physical beating the drivers were taking, Hamilton's comment something like; "I like it.."I wasn't awestruck by Hammie not passing out as much as I am speechless about the current cars lateral G capability and the drivers ability to function at that level over a race distance...
Cheers - Jim
