Page 1 of 2 12 LastLast
Results 1 to 40 of 46
Thread: F1000 For Sale
    Calgary, Alberta, Canada
    Liked: 26
    Default F1000 For Sale
    PLEASE SCROLL DOWN TO BOTTOM OF POST FOR THE CURRENT CAR, DROPBOX LINK, AND LIST / PICS OF EVERYTHING. CAR, TRAILER, SPARES, PIT EQUIPMENT, CHASSIS SET UP EQUIPMENT. Thanks
    We are selling one of the 2 F1000 race cars we currently run. In the pics from the Drop Box link you will see 2 race cars, both are Orange bodywork, both cars are identically prepared (save front lower A Arms) and all improvements inclusive of Chassis Strengthening have been done to each car. The car for sale is #42, white front and rear end plates, black A arms.
    You can see in the pics (welding shots) where and how we bolstered the chassis (GUSSETS, more tubes), we re-clocked the front Dampers as well for easier access and changed the wheel motion ratio to 1:1. now both ends of the car are 1:1. In addition the cheesy internal floor plate that bolted in was replaced with a steel plate that is now welded into frame rails. Pedal box brake assembly mounting plate with tons of front rear adjustment and NO FLEX when you push the pedal like it should be, NONE. We did most everything on these cars in the rebuild. The rebuilds were done in 2014 / 15. The car for sale was rented to Lappers this past year, no accidents, no crashes and not driven even close to the limit of the car.
    starting at the front of the car moving to the rear:
    - strengthened chassis
    - new bolt in / bolstered pedal box brake assembly mounting plate / 2 pedal foot box
    - clutch moved to steering wheel
    - new chassis powder coat
    - new brakes, 4 piston Wilwoods (front and rear)
    - new rotors
    - new pads
    - re-clocked front dampers (180 degrees)
    - front wheel motion ratio of 1:1 with new BRD Bell Cranks
    - new shifter Push Pull cable
    - new Rod Ends Aurora Golds
    - new brake lines and fittings with quick disconnect rear lines
    - BRD Dry Sump System
    - new BRD front wing profile (2015 BRD Profile)
    - new wing flaps (BRD 2015)
    - new Aim Data System (no damper sensors) All engine vitals, brake pressure front and rear, f1 style Aim Formula Wheel, GPS Track Mapping
    - new Aluminum front underside floor plate
    - new Tea Tray
    - new full width floor (BRD) A real flat bottom car inclusive of getting rid of the rear bulkhead bottom frame rail step
    - BRD Gen ii bodywork (Low Drag)
    - new BRD 2015 Rear Diffuser)
    - new BRD rear Aero End Plates Gen ii
    - Ohlins / rebuilt dampers by The Shock Shop Chris Bellings (just prior to his retirement)
    - new radiator
    - new oil cooler / radiator
    - new hoses
    - new floor
    - new AN hardware throughout
    - new paint
    - carbon fiber wrapped front wing, rear wing beam, rear wing upper, front flaps
    - 3M leading edge protection
    - new chain
    - new gears front and rear
    - added NACA DUCT side cooling vents to side panels
    - new Air Intake box
    - new fuel pump
    - new starter
    - new axles
    - new CV joints (Volkswagon and BMW)
    - new SPARCO belts good to 2020
    - new drive gear cluster
    - new battery
    - new ignition power cutoff switch
    - new wheels (Youngbloeds) 7" / 9" Also have a spare set
    - new shark fin radio antenna
    - wired PTT switch on wheel
    - No lift shift up / Auto Blip down shift system (Flat Shift Pro)
    we replaced 98% of the bits on the cars, Its probably easier to tell you what we didnt replace on the cars.
    Maintenance History
    We started July 2015 with A fresh GDRE GSXR 1000, fresh oil and oil filter, every 2 hours the oil is changed, every 4 hours the oil and filter are changed. Diff is inspected and serviced after every 120 minutes of on track duty, Chain replaced in August 2016. Nut bolt check after very session, chain waxed after every time the car comes off the track and tightened if needed. Once track days are done its back to the shop where we remove bodywork, remove pod floors, remove diffuser and inspect car from front to back, top to bottom. Blow the car out, vacuum the car, clean, if it needs something it gets replaced with new bits. We are fussy! Car has performed near perfect.
    New / Used Parts in the Parts Bin (our used parts are all fully functional, NO junk)
    - new fuel pump in the box
    - new starter in the box
    - new chain in the box
    - new front and rear gears, (some used some not, NO JUNK) providing full range of ratios that work with an f1000
    - new and some used Suspension springs, full compliment of weights, fact is we rarely changed the spring rates as our driver never really pushed the car to where she would notice a spring change
    - new Drive Flange kit complete
    - used, fully functional water radiator
    - vast used selection of AN brake lines with fittings
    - spare set of Youngbloed 7" / 9" wheels
    - trailering wheels
    - BBS 3 piece wheels on the shelf (these came with the car when I bought it, I have never used them, I think there is enough for 2 sets of wheels but like I said, we have never used them. whatever is there goes with the car
    So you will see 2 cars in the link, some shots of the Grey chassis (the one for sale) and shots of the Orange Chassis, both are identical under the skin. #42 uses STOHR GEN 1 lower front A arms, that is the only difference.
    September 2016 was the last time the car was run, here is the compression test numbers just after it came off the track but was allowed to cool down enough to touch. Starting at driver left moving to the right across the cylinders:
    cyl #1 190, cyl #2 187, cyl #3 194, cyl#4 190. Compression test was done with a relatively new MAC Tools Compression tester.
    If you require additional pics or have more questions feel free to ask.
    I have well over 75K USD into this car. Price as listed for sale $39900.00 USD
    Liked: 26
    heres a better pic of the sides of the car and the frame Bolstering:
    Liked: 26
    Bump
    Senior Member jose gerardo's Avatar
    el paso texas, U.S.A.
    Default North American F-1000 Championship
    Hello Fellow Racers,
    There is a new championship being organized in the North East part of the united states with cash prize money and almost a dozen sponsors, come and race with us.
    You can contact me @ joseg2@glabels.com or 915.726.0993
    Best regards and hope to see you on one of our races soon.
    Step on the gas until you see the bright light..... THEN BRAKE HARD !
    atlanta, ga
    Liked: 136
    Can you guys save that 2 hr old oil for me?
    Thanks!
    GC
    Liked: 26
    Sure! I can Fedex it down to you or do you want me to wait for the pipeline to be built....
    Price Reduction to $39,900.00 USD (Bump)
  8. The following 5 users liked this post:
    colorado
    Liked: 49
    Pristine car! What diff is it running?
    FYI - Drop box error: The folder ‘F1000 For Sale 2017’ doesn’t exist.'
    Liked: 26
    Thanks, it runs a Quaife. And thanks for the link heads up....
    atlanta, ga
    Liked: 136
    Blair - Pipeline reference was spot on!
    Liked: 26
    Seems that not all can open the Drop Box link so here are a few more pics. If you want a pic of something specific please let me know.
    Liked: 26
    Looks like I am at the box limit!
    Liked: 26
    Bump
    Liked: 26
    So, we made a few changes over the winter to the car, nothing mechanical, just the livery of the car. Here's a few shots of how it looks now.
  17. #14
    Liked: 26
    Some new pics above with a few cosmetic changes done to the race car.
    Liked: 26
    Here is a link to our FB page. Tons of pics and info. Our cars are Top Shelf. Have a look.
    https://www.facebook.com/58028903873...type=3&theater
  19. #16
    Liked: 26
    Race Car is no longer for sale. 2 new tracks coming to our area and the Rent a Ride program has garnered some good interest. Thanks all.
  21. #17
    Liked: 26
    Retiring from Racing.
    This car and all spares, pit equipment and trailer is back up for sale. The car has not turned a wheel this summer, it is Race Ready now. It has a fresh GDRE Suzuki GSXR in it. Car comes with all spares related to car. 4 sets of wheels, 1 set with American Racer slicks with a 20 minute session on them from last September, 3 sets of New American Racer slicks, 1 set of New Avons, 1 set of new Rain tires mounted on BBS wheels, 1 Spare fresh GDRE GSXR with a BRD Dry Sump installed. A good selection of Springs, a good selection of front and rear gears, 3 starters (new), one fuel pump (new). You can see in the parts pics most all spares are new. NO JUNK! The car is in excellent shape. front toe bar, rear toe bar, small aluminum stands, high chassis aluminum stand with upgraded wheels on it, Electric lift A frame, lift bar, Pit cart with collapsible trailer hitch, this is the tire rack, and nitrogen rack, it also has a conversion utility shelf, front jack, rear jack,10' x 20' Pop Up tent with zip in sides, one Trammel bar for jigging A arms
    Jesse Britsan from BRD can confirm the quality of this race car.
    The spare front wing / nose assembly is Fiberglass , the nose on the car is Carbon Fiber, it features the latest front flaps from BRD. All the wings are Carbon Fiber wrapped with 3M clear on leading edges
    The 28' Intech all Aluminum trailer is also for sale, trailer is currently designed for 2 Open Wheel cars stacked, Hydraulic Lift. It is a smooth skin outside and inside, it also has a 12' extension by 16' long electric awning, sway bar trailer hitch, CD player, internal speakers, external speakers, external sub woofer, external halogen lights, internal wall lights on dimmer switch, ceiling florescent, 1 Hammock, electric leg on the hitch side, 6 pit chairs.
    I have well over $130,000 in the car, spares, chassis set up, pit equipment and trailer.
    $47,500 for car , pit / chassis set up equipment and all spares,
    $65,000 for car, all spares, chassis set up equipment and trailer
    This car is Race Ready now, pull up with your truck, hook up to trailer , add gas and go race.
    pics of race car, spares, parts and trailer can be seen in this drop box link
    https://www.dropbox.com/sh/ul57a53a2...ypufijYDa?dl=0
    I can be reached at 403 464 5700 or blair@robertshawracing.com
  23. #18
    Default Retiring From Racing
    Dear Blair,
    are you able to rent your cars?, we need available rentals in the championship and the brd conversion on the stohrs have proven
    effective and competitive, also have you spoken to adam proctor of Australia?, they love stohrs and Mine is winning races out there, also how much for the trailer?.
    Regards
    Jose
  24. #19
    Liked: 26
    Hi, not really wanting to rent the car outside of my crew with it because if the car is out of sight for us we are unable to ensure a high quality, safe race car for the renter, and a fast and capable car. And, add the risk of an Operator who may time out parts well after they should be timed out, and or fail, leave me with a beat car. Cant do that.
    Have not yet touched base with Adam Proctor, thank you for the heads up.
    With respect to the trailer, first I have to sell the car and related bits. Selling the trailer first, land locks me and the cars. Hopefully the cars and bits go quick, it's .50 cents on the dollar and its all top shelf quality. if car doesn't sell with Trailer, I'll contact you.
  25. #20
    Liked: 26
    Also, if you go to the face book page, raceroomyyc, go to photos, we also have a Full Motion Simulator that is the exact replica of the Stohr chassis and body work, it has OBP 2 pedal hydraulic brakes, D-Box 2 DOF motion system, Rexing Carbon Fiber Formula wheel with Paddle shift and Clutches, Sim Ex Force Feed Back steering system, Carbon fiber / glass composite seat, wind system, retail would be 35K, its available for 20K. A great Training tool for any race car driver and more specific, if you are thinking about racing in the F1000 Pros Series, iRacing has most of the tracks mapped. you cant learn a track cheaper, and this sim is not your average sim, it is a great tool.
  26. #21
    Member RightTurnPromotions's Avatar
    Nashville, Tennessee
    Liked: 65
    Quote Originally Posted by jose gerardo View Post
    New? Jose you been running NorthAmF1000 for three years now.
    For others -
    The website is northamF1000.com - social media is NorthAmF1000 and check out our highlight videos here on Apex Speed.
    We run in SCCA Pro Racing under Formula Race Promotions (FRP) - Bob Wrights series.
    Stock engine rules (not allowing mods like club racing )
    Hoosier tires
    And over 40K in cash and prizes in 2019.
    Come race with us!!
    [SIGPIC][/SIGPIC]
  27. #22
    Liked: 227
    Quote Originally Posted by RightTurnPromotions View Post
    For others -
    Hoosier tires
    Come race with us!!
    The post was from 2017.
  28. #23
    Liked: 26
    Noticed some pics didn't upload to DROPBOX link. they are now up and some description of what all is in the pics
  29. #24
    Alberta, Canada
    [QUOTE=Blair Robertshaw;587796]Retiring from Racing.
    Can vouch that everything listed here - race car, trailer, equipment, etc is ALL top notch. This is a great deal for someone wanting a top notch racing setup. Sad to see you go BR, but good luck with the sale. Someone is going to get a very good deal!
  31. #25
    Liked: 26
    Twin's!
    The sister car to the one advertised above has also come for sale. It is near identical with the exception of the front lower A arms, they are gen 2 and have a tad different bolt up than the Gen 1 A arms. It is as follows;
    fresh GDRE GSXR (zero time), also BRD Dry Sump, has 2 sets of wheels with fresh rubber mounted. Racing Radios (2), headset,trailering wheels, spare chain, some gears, spare starter,
    You can see both cars in many of the pics in the drop box link and we have many more if you would like them sent to you. This car is over $70K USD to build as we have them.
    With respect to pricing, when you add this car value to what is advertised above we have just over 200K invested in cars, spares, set up equipment, trailer.
    $35K for this car (#44) or $97500.00 USD for both cars, all spares (a fresh GDRE GSXR), both cars run AIM data systems, all pit equipment, chassis set up equipment. If bought as a package, this number is $.48 cents on the dollar AND NO JUNK at this price. bring your Dually, pull up, inspect, pay, tow to a race.
  32. #26
    Default Thanks Cory
    , sometimes people get ahead of themselves and Don't check the origin of the information they read.
    Come and race guys, this is the only thing that Matters, everything else is just waiting............
  33. #27
    Liked: 26
    bump
  34. #28
    Liked: 26
    I can make Race Car available without spares, trailer and set up equipment as well.
  35. #29
    Liked: 26
    Here are pics of the last time the car (21) was rented (pic3). Since then, it has had an engine fresh, complete front to back, it's fresh, it's tidy, it's clean, and the spares are not junk. A BRD Carbon Nose and new Flaps / End Plate Ramps have been added, here is a pic of the end-plate assembly. And ONLY the nose is Carbon, everything else is Glass with Carbon Vinyl wrap, end plates are out of aluminum. The Dzus buttons have also been replaced with Matt Black finish buttons. The middle pic shows the new BRD design Break Away Wing, VS the old Whisker style mount which is seen on the side view of race car.
  36. #30
    Liked: 26
    New pricing as some of the equipment has been sold
    Race car #21 / $35,000 race ready, zero time George Dean, GSXR installed. Car is Race Ready. includes spare front nose and wing assembly, spare front wing, low DF front flaps. A good selection of Springs, a good selection of front and rear gears, 2 new Drive axles from Taylor, 3 starters (new), one fuel pump (new). You can see in the parts pics most all spares are new. NO JUNK! , 3 sets of wheels, 2 with slicks (one set fresh, the other has a 20 minute session on them), one set of Hoosier Rains, brand new on BBS wheels, Tramell bar for jigging A-arms, Toe Bars, Toe Board, Chassis stand, front and rear Lift jacks, new Spare Aurora Gold Rod ends, and many other bits too numerous to list but they go with the car and again, NO JUNK bits or spares.
    Intech smooth skin Aluminum 28' Trailer, 2 x 6000 lb axles, new was $44,770.00 USD new price at $22,750.00, includes trailer, hitch with sway bar, 10 x 20 Pop up tent with zip in walls, 4 x pop up tent corner weight anchors, Stainless BBQ, Hammock, some ratchet straps, 6 chairs, 4000 lb Hydraulic lift, internal and external speakers with Sub Woofer, CD player, halogen internal and external lighting package, Halogen wall lights on dimmer, Flourescent ceiling lights, 12' x 20' electric roll out awning, new tires 2000 miles ago, new batteries in 2017, hydraulic jack, Pit Pal door cupboard with fold down table, 3000 watt Honda Generator.
    Spare GSXR with BRD Dry Sump, Fresh by George Dean Racing Engines $6500
    Also have 4 sets of new rubber, 3 x American Racer F1000 compound, 1 set of Avon Gumb balls. AR at $500 a set, Avons at $900
    Thanks all
    Last edited by Blair Robertshaw; 01.14.20 at 1:45 PM. Reason: Added Trailer description with new price
  37. #31
    Liked: 26
    updated Trailer Description with new lower price above this post.
  38. #32
    Denver, CO
    Liked: 80
    Blair,
    You may want to clarify since the thread is so long - are both the #21 car, #42 car, and the trailer all still for sale, or is one of the cars gone?
    -Jake
  39. #33
    Liked: 26
    Thanks, yeah its getting to be like War and peace. I will rewrite it on the weekend but until then, both 21 and 42 race cars are available, 21 has the extensive spares, and trailer is still for sale as well. Thanks again for the heads up Jake
    Quote Originally Posted by JakeL View Post
    Blair,
    -Jake
  40. #34
    Liked: 26
    Default Repost with clarity and lower pricing
    1. Race car #21 / $35,000 Race Ready, zero time George Dean Racing Engines, GSXR installed with BRD Dry Sump. 1 spare GSXR with BRD Dry Sump (needs freshening)
    2. Car package includes; AIM Video Camera, Aim Data System, Aim Formula wheel, Bump shifter, Lap Top, complete spare front nose and wing assembly, spare front wing, low DF front flaps, good selection of Ohlin Springs from 600 to 1000lb, front-drive gears and rear-drive gears, vast selection so a guy should be able to dial in track specific gearing, 2 new spare Drive Axles from Taylor, 3 starters (new), one fuel pump (new). Car comes with Radio(s), 2 x Motorola XPR 6350 (shown in pics). Most all spares are new. NO JUNK! , 3 sets of wheels, 2 Jongbloed with AR slicks (one set fresh, the other set has a 20 minute session on them), one set of new Hoosier Rains, on BBS wheels, Trammel Bar for jigging A-arms, Toe Bars, Toe Board, MK Technologies rolling Chassis stand, MK Technologies Electric A frame lift (newly added), MK Technologies front and rear Lift jacks, new Spare Aurora Gold Rod ends, 15 Gallon Fuel jug with Crank pump, Trailering Wheels and many other bits too numerous to list but they go with the car and again, NO JUNK bits or useless spares. Pics are located in the link below.
    Also available but not included in the above package;
    - 1 x Fresh George Dean Racing Engine, GSXR 1000 with BRD Dry sump installed $6000 (new lower price, was $6500)
    - 2 new sets of American Racer (F1000 compound) slicks $1000 / $500 ea
    - 1 new set of Avon slicks $900
    - Car 44. Sister to this car, fresh GDRE GSXR (zero time), also BRD Dry Sump, has 2 sets of wheels with fresh AR rubber mounted. Racing Radios (2), headset,trailering wheels, spare chain, some gears, spare starter, $35,000
    - 28' Intech smooth skin Aluminum Trailer, 2 x 6000 lb axles, new was $44,770.00 USD new price at $22,750.00, includes trailer, hitch with sway bar, 10 x 20 Pop up tent with zip in walls, 4 x pop up tent corner weight anchors, Stainless BBQ, Hammock, some ratchet straps, 6 chairs, 4000 lb Hydraulic lift, internal and external speakers with Sub Woofer, CD player, halogen internal and external lighting package, Halogen wall lights on dimmer, Flourescent ceiling lights, 12' x 20' electric roll out awning, new tires 2000 miles ago, new batteries in 2017, hydraulic jack, Pit Pal door cupboard with fold down table, 3000 watt Honda Generator.
    pricing is USD
  41. #35
    Liked: 26
    Default Lowered Price
    New price for the package below is $32,000 USD
    2. Car package includes; AIM Video Camera, Aim Data System, Aim Formula wheel, Bump shifter, Lap Top, complete spare front nose and wing assembly, spare front wing, low DF front flaps, good selection of Ohlin Springs from 600 to 1000lb, front-drive gears and rear-drive gears, vast selection so a guy should be able to dial in track specific gearing, 2 new spare Drive Axles from Taylor, 3 starters (new), one fuel pump (new), spare set of injectors, 2 batteries. Car comes with Radio(s), 2 x Motorola XPR 6350 (shown in pics). Most all spares are new. NO JUNK! , 3 sets of wheels, 2 Jongbloed with AR slicks (one set fresh, the other set has a 20 minute session on them), one set of new Hoosier Rains, on BBS wheels, Trammel Bar for jigging A-arms, Toe Bars, Toe Board, MK Technologies rolling Chassis stand, MK Technologies Electric A frame lift (newly added), MK Technologies front and rear Lift jacks, new Spare Aurora Gold Rod ends, 15 Gallon Fuel jug with Crank pump, Trailering Wheels and many other bits too numerous to list but they go with the car and again, NO JUNK bits or useless spares. Pics are located in the link below.
  42. #36
    Liked: 26
    Default 2020 price reduction
    1. Race car #21 / $29,000 Race Ready, zero time George Dean Racing Engines, GSXR installed with BRD Dry Sump. 1 spare GSXR with BRD Dry Sump (needs freshening)
  43. #37
    Liked: 26
    R
  44. #38
    Default Race car for sale
    PLEASE !!
    Someone buy this car and take it out and enjoy it, the deal is UN believable in value, there has been a bit of F-1000 shuffling around the country with a very strong championship running with FRP in the east coast and multiple groups organizing elsewhere around the country.
    PLEASE BUY THIS CAR AND RACE IT !!!!
  45. #39
    Denver, CO
    Liked: 80
    Hola Jose,
    I used to know a guy that was BAD fast in a Stohr. Big goofy Mexican guy, maybe you know him?
    These cars do look super primo though...wow.
    -Jake
  46. #40
    Hola Jose,
    -Jake
    si !!
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. LEE RED Racer
