Results 1 to 13 of 13
    Chicago
    For Sale 2008 Red Devil Formula 500 and Spares
    2015 ground up rebuild.
    Powdercoat frame.
    6 races since rebuild
    2008Red Devil Formula 500 with 494 RAV engine with spare parts and equipment. Fresh rebuild
    Engine:
    • 1 complete regular 494 Rotax engine 1 race weekend.
    • 1 Carb rebuild kit
    • 2 Spare magnetos (new)
    • 2 Spare ignition units ECU (new)
    • 1Spare fuel pump (new)
    • 2 Used ignition systems (good condition)
    • 1 spare exhaust pipe (used)
    Clutch and drive train:
    • 1 Arctic Cat drive clutch
    • 2 Driven clutch sprockets
    • 3 Spare gear (drive) set
    • 3 Spare clutch springs
    • 1 Spare final drive belt
    • 2 Spare primary drive belts
    • 1 spare mount for secondary clutch pulley bearing
    Suspension parts:
    • 2 New rear hubs
    • 1 Spare steering arm (fits either side)
    • 1 Spare set front shock struts with rod ends
    • 1 Spare set tie rods with rod ends
    • 1 Set (4) digital scales (365 lb. capacity each, so that wheel weights fall into most accurate range of scales)
    • 2 Rear bearing brackets (new)
    • Front and rear bearings
    Brake Parts:
    • 1 Spare front caliper mount (fits either side, new)[/SIZE]
    • 1 Brake Bleeder system
    • 2 sets brake pads (like new)
    • 1 Spare rear caliper
    • 1 Qt. Red Line high Temp Brake Fluid
    Fire System:
    • 1 Recharge kit
    • Miscellaneous fire extinguisher system fittings and replacement parts
    Tools and Setup Equipment:
    • 1 Set (4) digital scales, 365lb. capacity each, so wheel weights fall into most accurate range of scales
    • 1 digital level for caster/camber
    • 1 set (4) bolt on plates to place wheels for more accurate chassis setup (aluminum)
    • 1 Laser project wheel tracking
    • 1 Toe in bar for use with dial indicator for accurate toe setting (dial indicator included)
    • 1 Longacre tire pyrometer (digital)
    • 1 tire gauge
    • Spare weights
    Miscellaneous Parts and equipment:
    • 1 Compression Gauge
    • 1 Spare water overflow system
    • MyChron 4 dash system with GPS and computer download access
    • Bolts and nuts to replace any bolts on car
    • Wiring parts to fix any wiring on car
    • Wheels and tires for trailering (4)
    • 3 Sets racing wheels
    • 1 New set rain tires (mounted)
    • 1 My Laps transponder
    • 1 Car lift (Electric)
    • 1 Quicklift jack
    Price: Car and Spares - $10,500 (Car Only - $9,000)
    Contact: Robert Selck (608) 290-9412 or rwselck@yahoo.com
    wi
    This is a car that Steve Jondal had before the present owner. It is well sorted out and cared for. It can run with the best. It was gone through from top to bottom last year and i believe it only had two race weekends on it since then. This is a car that is ready to go and a bargain. The spare list is also new parts.
    Wisconsin
    New Price. 2016 Car had a second at Blackhawk Major and a3rd at the Cat Nations.
    Chicago
    Default Price reduction
    Price of car and spares lowered by $1,000. Great car to get out this Spring!
    Liked: 227
    This car is a deal! A nationally competitive car, with good manufacturer support, for under $10k.
    Wisconsin
    New Price! Car and spares $8000.00
    AWS
    Marietta,Ga.
    Liked: 61
    Default Pictures
    Robert, you might want to show some photos with the slicks mounted on the car to show a potential buyer that is unfamiliar with the F500 class. At $8000 this is a steal.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    Knoxville,Tn
    Liked: 65
    I don't know, transport wheels are a delightful change of pace.
    Chicago
    Default Additional Pictures
    Wisconsin
    Default New Price
    New price $6000.00 ! Car and with spare engine and clutch. Also includes 2 sets of tires and wheels . If car does not sell by end of June , will parts car out.
    Wisconsin
    Member Sully's Avatar
    New Boston, MI
    What does it weigh without driver?
    Nick Sullivan
    F5 #92
    '97 Red Devil T-27
    facebook.com/SullySpeedShop twitter.com/SullysSpeedShop
    Wisconsin
    Quote Originally Posted by Sully View Post
    Car is Sold Thanks Apex
