SCCA Log book is up to date as of July 2016.
Its a Stohr 2007 Gen 1 chassis #006 with the new Brittsan Racing Development bodywork on it. ($8,000.00 Upgrade in Aerodynamics)
Braking system in it's entirety is brand new, lines, calipers, Rotors, master cyl.s (Tilton 75 series)... -2an braided lines out to all wheels.
AFFF 10 lb. bottle in the green
Ballistic 2.2 lb Lithium Battery
Seat Belts are New Schroth and good till end of 2018
ATL 8 gallon fuel cell with Fuel level gauge in the cockpit / sending unit fron ATL installed
Custom Fuel access door and hidden (much safer location) Fuel tank fill cap setup.
Jongbloed three piece 330 series 6" fronts, 8" rears, polished aluminum finish
Custom Stainless steel 4 wheel Alignment plates
Shocks are 3 way adjustable C2P's, freshly tuned up and Dyno'd by the 'Shock Shop'.
GSXR1000 Engine freshly gone through and Dyno'd by George Dean. Only 2 Majors events on Engine. Once race in 2015, one race this summer.
Header is Ceramic coated Inside and Out, is a 4 into 2 into 1 setup.
K&N Air Filter
All 4 CVs are new and the Lightened ones from Pegasus.
The 4340 drive shafts were custom drilled also.
Car weighs in at 809 lbs. with 1 gallon of fuel.
I'm 6'2" tall and 205 lbs. and fit fine...
Price is $30,000.00 Make me an offer!
Doug 719-565-9773
coxmotorsports@skybeam.com
