! ! ! SOLD ! ! ! Thank you Apex Speed
For sale: Van Diemen Model RF98K Cassis No. 2498. I still plead a little ignorance about the car but here's what I know: The car had a lot of development by a previous owner. See link below for more info. on this car and the sister car. It does have the wide track suspension. It has front and rear cockpit adjustable sway bars. I bought the car with confidence because I know the care/prep it had by the immediate previous owner, Dr. David James and Briton West Motorsports. It is a very nice handling car which I think can be seen by my first outing with the new radial tires at the Glen Major and lap times in the low/mid 2:03s. The engine in the car is a Farley, aluminum head, that has been freshened by Briton West Motorsports - it's probably close to needing a refresh. The spare is a Farley with a cast iron head - I was told this is the strong motor and has very little time on it. There's 20 pounds of ballast in the car. I weigh about 195 and just make weight. I'm selling because I have one kid in college and one following soon. I'll work on posting some pictures in a night or two.
The car comes with the following spares and parts in no particular order:
8 OZ wheels
10 MADIN wheels
Used tires include: 1 mounted set of radials with 3 heat cycles, 1 set unmounted radials 5 heat cycles, 1 set mounted radials with unknown heat cycles, but they were as fast as new tires (go figure), 1 set unmounted 4 cycle bias plies, 1 Single brand new bias ply rear. 1 set used mounted bias ply full rains and 1 set mounted grooved bias ply intermediates. barely worth mentioning, but good for just some track time is a set of unmounted bias plies with 9 heat cycles.
AIM MXL Data system with:
GPS with predictive lap timing
Aim SmartyCam
Front brake pressure
Rear brake pressure
Throttle position
4 shock inputs
Penske Shocks (rebuilt 9 race weekends ago)
3 used Radiators (replaced with new 9 race weekends ago)
Hans Specific pull up belts good thru 2019
Current SCCA Annual (last month)
MK Technologies 24" jack stands
MK Technologies 5" jack stands
Quick Jack
22 gear sets
1 new Bosch starter
3 new Brake master cylinders
2 sets new blue brake pads
2 sets like new black brake pads
3 new points conversion ignitions
1 spare distributor (looks like new)
1 new Bosch coil
1 new Bosch cap
new sets of plugs
Misc used ignition parts
Fiberglass seat insert (I don't use this but someone smaller might)
1 used upright - looks OK
1 used upright - broken studs in top - needs work
1 used half shaft rolls flat - looks OK
1 used rear upper suspension mount (Billet Aluminum)
2 new support rods for above
Misc engine seals
misc camber plates, front and rear
misc wheel shims
misc oil coolers, hoses, cooling lines
1 used Tilton Clutch
1 used AP clutch
1 used clutch disk/plate (measures new)
5 head gaskets
2 misc engine gasket kits
2 header gaskets
1 new K&N air filter
1 hood scoop
1 lot misc other gaskets
10 oil filters
9 quarts Redline gear oil
9 quarts Joe Gibs XP3 Driven motor oil
2 fuel pumps
1 lot misc. carb springs, jets, gaskets
1 original sway bar and linkages
1 new front upper A arm
1 new front lower A arm
1 new rear upper arm
1 new rear left lower A arm
1 new rear right lower A arm
1 new front push rod
1 new rear push rod
http://www.apexspeed.com/forums/show...n+Diemen+RF98K
Here's a link to a current picture: http://www.scca.com/events/1981178-m...-international
Asking Price: $20,000
