I have a 16' enclosed and would like to go up to a 20' or 24' for a number of reasons. This could be a brand new trailer or could be used.
This is my first trailer and while I've learned a lot about trailers, tires, bearings, and towing. But I know I have a lot more to learn and when I'm looking for a new trailer for the purposes of motorsports (and not just for my current very small formula car), I'm hoping people here can help give me some direction.
I need it to be at least 8' wide, I believe. Though I'm not sure why I wouldn't just go up to 8.5".
The reasons to go wider or not are probably my biggest area in needing help. If I go 8.5' I'm assuming the wheel wells will bump into the inside trailer space. Is this a big deal or do most of you have trailers that have the wheel well bumps in your trailer? I pull with a large GM gas SUV. At 8' or 8.5' will I need to get extended side mirrors to see around it?
The other is V nose or not. I hear about better gas mileage and if it's just a consensus that V nose is the way to go, maybe this is an easy question...other than it costing more.
I don't believe this trailer will be aluminum. I think long term I may want an aluminum trailer at some point and while I'll shop it, my guess is that it is substantially more expensive and this will not be the last time I upgrade my trailer in one way or another, I'm sure.
If I go new, or even used, what are the manufacturers that I should definitely check out or if there are some I should definitely stay away from that would be helpful as well. Best I've got is to steer toward manufacturers that have been around and will likely be around for a while but I'm not sure who this is other than some google searches. But some references here would be very helpful.
Other than that, I don't know what I don't know. Should I be asking questions or considering anything else as I shop for a new to me trailer?
Thanks for the advice in advance!
