20ft Enclosed Trailer LOADED! 20 Foot enclosed race car trailer LOADED. Less than 5k miles on it. Purchased 2014. 7K lb Axles
This thing has everything you need. To run your Vee etc. for the weekend. Never borrow from the guy in the next pit again. With the wench, power tongue, etc. You won't even need crew.
1. Roof Solar panel (40watt) with charge controller. (Will easily recharge on board battery in a short time.)
2. 1500 Watt inverter. (will power the on board air compressor, battery charger etc.)
3. LED Lighting (in and out)
4. Battery Charger (AGM, GEL, or Standard at up to 10 amps
5. Compressor (will run small air tools quickly fill tires, etc.)
6. Battery
7. 2000 lb winch (for loading car)
8. Space Heater (only for external 110 AC from generator, etc.)
9. Power tongue lift with light
10. Loaded with Pit Pal products. (Fuel Jugs, Oil jugs, Radio stuff, paper towels and more.)
11. Tire/wheel rack
12. Light work bench.
13. Fire Extinguisher
New they sell for $3700 and this is like new with over $1500 in added features. $3800 OBO. Jim (859)252-2349 or jim at sracing.com . (located Lexington, KY) Possible partial delivery. (5/27/15)
http://www.sracing.com/ForSale/forsale.htm for lots of photos.
