Does anyone have any information on why the rule change is recommended? If it's a spec class and everyone is supposed to deal with the same hand of cards everyone else has, then why is this change needed? I see no reason to create more "options" in a spec class.
Wicker bill (Gurney flaps) are permitted as an option for installation on the trailing edge
upper surface of the wing element. They must be attached in a secure fashion,
without modification to the wing element except for mounting hardware. Total
height is .250” on one or both elements. The Gurney flap only, may extend beyond
the parameters of the end plate. Maximum number of mounting locations is 5 and
maximum hardware size is #8 (.156). Gurney flaps, where attached, shall be 90
degrees and parallel to the upper surface of the wing element and no taper or “saw
toothed” Gurneys are permitted
