Results 1 to 19 of 19
    Sacramento, CA
    Default Aero grip is a drug
    There is no way you can comprehend how significant grip is at high speed unless you put your butt in a winged car. I've raced a few regionals in an FE and it still takes me a few laps each session to trust the tires in flat-out corners... then I hate to get off the track when the checkered flag is waved.
    If interested, here is a lap at Roebling Road from last weekend's race.
    http://youtu.be/mOcEP4Wgnp4
    San Mateo, CA
    Liked: 47
    Say goodbye to your wallet and hello to your crack, I mean tire dealer. The aero is really fun on the brakes as well.
    Senior Member Evl's Avatar
    Nashville, TN
    Nice video production, Joe, and great meeting you last weekend!
    Roebling really does stretch out the neck, doesn't it?
    Hope to see you out there again soon,
    -Chris
    #45 FE - Personal twitter: @AOERacing
    RaceTimer+ and business twitter:@Epipiphero
    Atlanta, Ga
    Enjoyed the video, thanks!
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    2004 Mygale SJ04 Zetec
    Quote Originally Posted by Joe Reppert View Post
    In that case you should try a car with some downforce...
    SoCal
    Liked: 102
    Driving a FF in a run group that included FA showed what downforce does. I was surprised to discover that in first gear corners and twisty segments, I could run right with the Atlantics. I was shocked by how fast an Atlantic could pass me on the outside while I was teetering on the edge of disaster in a 4th gear corner. It was amazing.
    Does anyone here know approximately how much downforce is produced by an FE at, say, 130 mph or so?
    Lexington KY
    Liked: 50
    Quote Originally Posted by Rick Ross View Post
    Steve Lathrop told me that a FC Citation got about 500 lbs. (Of course use of wickers and wing angle will make a difference.)
    859-252-2349 or
    859-339-7425
    http://www.sracing.com
    Nashville, TN
    Not knowing the real value, I'd guess 250-300lbs, based on comparing cornering G vs speed.
    Red Neck Riveria, FWB, FL
    Liked: 105
    Default Dang!
    Missed that video - but sounds real interesting, and I'd really like to see it. Anybody have a copy - or link they could send/repost.
    TIA and Cheers - Jim
    third stone from the sun
    Liked: 101
    Downforce is an aquired drug!!!!
    Dee
    rt 5
    rt41
    Liked: 1494
    shouldent it be more like 1200lbs? If the car shows 2.5g, and sticky slicks will get you to 1.3/1.4-ish, you'd need another 1200lbs???
    Liked: 1411
    Down force numbers are expressed in pounds of down force and some speed. 150mph is typically used for FA and higher formulas. It is quite possible for an FC to make 1200 lbs. down force at 150mph. But you don't have the HP to do that.
    FC performance is getting close to the limit of what we can get the tires to do.
    One reason winged cars gain over non-winged cars is because down force is applied to the tires close to evenly side to side. With the down force one gains a lot of performance from the inside tires that is not possible in a non-winged car.
    The Lola T97 Indy Lights will make close to 2400 lbs. at 190 mph. I think the numbers for the Swift 016 is close to 2200 at 150. The Dallara Indy lights tops out at something like 1800 at 190 mph.
    Just some numbers to compare against.
    Our data showed that our FE made about 900 lbs Df at around 130+ mph. Do not remember the details but this is a good ball park.
  16. #15
    Member airindy's Avatar
    Michigan
    Well understood! I come from sprint cars, winged and non winged, dirt and pavement, and yes those huge wings can help you do wonderful things!!! Hope to get in a Formula car soon!
  17. #16
    Marietta,Ga.
    Liked: 61
    Steve, any figures for the 83 rt5?
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
  18. #17
    Liked: 1411
    Given that that car was a tunnel car, my bet is that it made well over 1500 lbs. maybe 2000 lbs.. But the tunnels were not all that wide. The flat bottom ground effect cars made a surprising amount because they had a very large surface area to work with.
  19. #18
    Austin, Texas
    The 2 seater Wolf is about 1900. Single seater Wolf is > 2200.
    Yes this is usually spec'ed at 250 kph or 155 mph
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
  20. #19
    Contributing Member Ty_Handke_83's Avatar
    Ontario, Canada
    Liked: 18
    Quote Originally Posted by turnbaugh View Post
    So if you have a 300 lb passenger, that equals things out then, right?
    Ty Handke
    HMST Inc.
