Results 1 to 26 of 26
Thread: HPD
    Muncie, Indiana
    Liked: 1038
    Default HPD
    A few photos of the new HPD in an 014
    Muncie, Indiana
    Liked: 1038
    another view
    locust valley, ny USA
    Liked: 146
    so you don't have to turn your heads 90*
    Liked: 146
    oh and suffice it to say, i think i want one.
    H-Town, Texas
    Are there any specs on that engine? Displacement? Ponies?
    Ken
    Midland, MI
    Liked: 312
    Default Web Site...
    From the HPD web site : HPD K20 – Formula Atlantic Engine
    No hp listed but I believe in the 2005-2006 RSX it made 210 @ 7800 stock...
    Chris Pruett
    Swift DB1
    We could put one of these to good use!
    atlanta, ga
    Liked: 136
    Default The HPD link above
    shows what looks like one of these engines in a PFM chassis - pretty cool.
    Liked: 562
    If it's anything like the FF Fit engine, it sure sounds like a great thing for FA.
    Is it a stock long block off the assembly line (like the FF Fit engine)?
    Linden, Ca
    Liked: 25
    Will that fit in my Van Diemen?
    Charlton, MA
    Liked: 6
    Is it a DOHC or a SOHC? The HPD site says its single overhead cam; elsewhere, it states the K20 as dual overhead cam.
    C. Skowron
    Austin, Texas
    What power does this engine make?
    Price?
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
    ApexSpeed Photographer Dennis Valet's Avatar
    Long Island
    Liked: 60
    I thought they were having trouble fitting this in 014s, in terms of the underbody aerodynamics?
    Huntsville, AL
    Default HPD
    The rear of the engine did require cutting into the tunnels some for clearance.
    Contributing Member quartzracer's Avatar
    On the "Honda Atlantic" Web site they have a video of the car running at "Willow Springs" can anyone tell me what track configuration they are using? Thanks
    Wisconsin
    Liked: 1482
    That is not this car in the video, but the PFM with the Honda in it that (I think) Jon Baytos did last year.
    Indianapolis
    The HPD guy at the show said that they will have install kits for the 014 and 016 Swift, he said the kit price all inclusive was $22k. The tunnels looked stock but the engine cover will be ugly to accommodate the intake and exhaust on the wrong side. HPD guy said rebuilds at 3k miles and 270 hp, also said motor is not sealed and HPD will not do the rebuilds, independent motor builders will do that.
    Contributing Member sherwood's Avatar
    Lakeville NY
    Quote Originally Posted by Paddy O'Brien View Post
    Hi Brooks , That is not bad at all, considering a good fresh Toyota is close to that number. Wish they were doing 41's Did they have an estimate for rebuilds?
    Indianapolis
    Mark, The guy I spoke with said that they will not be doing rebuilds but expect shops like Loyning and Elite to do so. HPD guy said there has been no testing of the combo yet, sounds like Swan racing will be doing some of it. He said that the Atlantic "Pro" series has accepted the engine in their series but that install work was not done yet and may not be ready til mid 2014.
    Indianapolis, In
    Liked: 32
    Default HPD Sealed?
    Are these to be a sealed engine by HPD or can anyone assemble and install a K20 in an Atlantic car?
    atlanta, ga
    Liked: 136
    Quote Originally Posted by quartzracer View Post
    I thought it might be "The Streets of Willow", w/ the big track in the background?
    Muncie, Indiana
    Liked: 1038
    Brooks, I believe the engine package is $22k, the bellhousing is additional as I recall. It would be best to contact HPD to confirm. Also, the car/engine at PRI has not been run.
    Liked: 1592
    yup, that's the streets
    Thanks, looks like a nice place to play is it smooth?
    Eric
    Liked: 977
    Default Ummm...
    Eric
    Most areas are fairly smooth. Some of the transitions will rattle your brains in a stiffly sprung formula car. It depends on how the track is configured.
    Senior Member SilverCarbir_FC26's Avatar
    Oconomowoc, Wisconsin
    Liked: 31
    Quote Originally Posted by Chuck Skowron View Post
    C. Skowron
    The K20 is a DOHC engine, the question is what K20 engine configuration will be used and what will be added or removed from the engine.
    Here is some info and background information on this engine.
    http://en.wikipedia.org/wiki/Honda_K_engine
    Because racecar...
