A few photos of the new HPD in an 014
another view
so you don't have to turn your heads 90*
oh and suffice it to say, i think i want one.
Are there any specs on that engine? Displacement? Ponies?
Ken
From the HPD web site : HPD K20 – Formula Atlantic Engine
No hp listed but I believe in the 2005-2006 RSX it made 210 @ 7800 stock...
Chris Pruett
Swift DB1
We could put one of these to good use!
shows what looks like one of these engines in a PFM chassis - pretty cool.
If it's anything like the FF Fit engine, it sure sounds like a great thing for FA.
Is it a stock long block off the assembly line (like the FF Fit engine)?
Will that fit in my Van Diemen?
Is it a DOHC or a SOHC? The HPD site says its single overhead cam; elsewhere, it states the K20 as dual overhead cam.
C. Skowron
What power does this engine make?
Price?
I thought they were having trouble fitting this in 014s, in terms of the underbody aerodynamics?
The rear of the engine did require cutting into the tunnels some for clearance.
On the "Honda Atlantic" Web site they have a video of the car running at "Willow Springs" can anyone tell me what track configuration they are using? Thanks
That is not this car in the video, but the PFM with the Honda in it that (I think) Jon Baytos did last year.
The HPD guy at the show said that they will have install kits for the 014 and 016 Swift, he said the kit price all inclusive was $22k. The tunnels looked stock but the engine cover will be ugly to accommodate the intake and exhaust on the wrong side. HPD guy said rebuilds at 3k miles and 270 hp, also said motor is not sealed and HPD will not do the rebuilds, independent motor builders will do that.
Mark, The guy I spoke with said that they will not be doing rebuilds but expect shops like Loyning and Elite to do so. HPD guy said there has been no testing of the combo yet, sounds like Swan racing will be doing some of it. He said that the Atlantic "Pro" series has accepted the engine in their series but that install work was not done yet and may not be ready til mid 2014.
Are these to be a sealed engine by HPD or can anyone assemble and install a K20 in an Atlantic car?
Brooks, I believe the engine package is $22k, the bellhousing is additional as I recall. It would be best to contact HPD to confirm. Also, the car/engine at PRI has not been run.
yup, that's the streets
Thanks, looks like a nice place to play is it smooth?
Eric
The K20 is a DOHC engine, the question is what K20 engine configuration will be used and what will be added or removed from the engine.
Here is some info and background information on this engine.
http://en.wikipedia.org/wiki/Honda_K_engine
Because racecar...
