Thought we had these two cars sold two weeks ago at $26k per car including extra set of wet and dry wheels (no tires) plus spares at cost, but have not heard back so am offering the same deal first come first served.
Chassis 37 as listed below (also with very nice red car cover). 73 has matching blue cover.
Stored inside or in trailers. We have never had a problem with either car.
A 24 ft Pace Shadow GT Daytona Tag trailer with custom cabinets, generator, tongue box, diamond plate floor, custom ramps, air con, huge sunshade, electric tongue lift is also available with car purchase.
Professioinally Assembled
SCCA Enterprises Car Build # 37
Color: White
I do not have race results handy, but this car won the 2004 and 2005 SAARC Championships.
SCCA Updates
-Lightened Clutch and Flywheel
-Gears
-Side Plates (Rear Wing)
Pi Clubman Data Acquisition and analysis software
-X-Sport Dash
-Wheel speed sensor
-G sensor
-Throttle position sensor
-Brake Sensor
-Fuel Pressure Sensor
-Temperature Sensor
Wired Radio with high gain antenna
two SPEEDCOM dual talk radios
two SPEEDCOMdual talk radio fast chargers
dual talk SPEEDCOM crew chief headset
SPEEDCOM helmet kit
high gain (salt shaker) antenna in black
Crew chief belt
TeamTech 6pt. Racing Harness in red
2 x Sets of Wheels (non raceable rubber)
1 x Set of Rain Tires (old - never used)
High Visibility Side Mirrors
Bead Seat and Original fiberglass seat
The engine cover has been partially painted red. Other graphics are vinyl and can be easily removed. This car is one owner, one driver in good condition- not a rental and not abused. Car currently needs front right and right rear corners from contact at last event (parts needed included). Cost to replicate with shipping, assembly, data upgrades, radio, enterprises updates etc. easily exceeds $65,000.00. Car last ran at Daytona in 2005.
Log book will need to be signed by scrutineer after inspection prior to competition participation due to contact. Obviously, you must have a valid SCCA competition license to run this car at SCCA events. Run your next event sfter nut and bolt, new tires and a fresh fluids.
This car does not have the updated shocks, steering rack or rear wing vents. There are other updates since 2006, but I do not have a list.
Comparing 37 and 73: 37 is white, and includes the X-Sport Dash, but needs two corners repaired (I have all the parts which are included). Chassis 73 has had about 10 less races, is blue and is turn-key.
Also available various spares and alignment/set up tools.
These cars have not been on track since December 2004. Be realistic and understand you will need to (and want to) thoroughly sort the cars over the winter.
Jeff Snell
jsnell@enlign.com
919-624-1124
