Results 1 to 14 of 14
Thread: Pfm - sold
    Calgary, Alberta, Canada
    Liked: 26
    Default Pfm - sold
    2006 Pro Formula Mazda chassis # 06-599
    $75,000 USD
    Car is prepared as follows;
    Car is current to 2013 Pro Mazda Championship Spec*
    Car had winter rebuild this past spring, one lapping session in 2013, about 800 miles on fresh engine and included in that number is 400 miles since winter rebuild / service.
    New AN bolts throughout entire car
    New Aurora Gold PRM rod ends
    Carbon wing package front and rear
    Lightweight pod tops, shock cover and engine cover
    New 2013 air box
    New NO lift shift button
    New coils last July
    New injectors last July, flowed at the same time
    New plug wires last July
    New fire system last July
    New Braille Carbon Battery 2011
    New water radiator last June
    New oil cooler last June
    New auto fan last July
    New 12 position fuel trim switch
    New fuel pump July this year
    New gear position sensor July 2013
    ECU 2012 update
    New brake pads last July (3 race weekends on them now)
    MOTEC ADL2 logging system
    MOTEC Canbus USB (you need this to get engine data)
    MOTEC Chassis data download cable
    New APV Valve
    Brake, throttle, steering, damper sensors
    New front damper sensors this year
    Indy Car Icar warning light system
    Rear carbon cone
    Carbon diffuser
    3 sets of wheels, 2 sets with new GY slicks mounted, one set with one year old rain tires, used once about 150 miles on them
    Pro exhaust system
    Club exhaust system
    Super trap club exhaust for those really low DB tracks
    MK front lift jack
    MK rear lift jack
    MK String Toe bars
    19 MM front sway bar
    20.5 MM front sway bar
    Trailering wheels
    Willans Belts good to 2017 / HANS width
    Great spring selection (400 -1000 lbs)
    New ackermans 2012/13 spec (yet to be installed)
    FTR gear box freshened last June by Taylor, about 800 miles since freshen
    Short stack gear cluster
    Tall stack gear cluster
    Current motor installed in car June 2013, Star sealed, about 800 miles on it
    Spare engine,Sealed SM Engine (with Alternator and Timing pick up)
    Engine case
    Updated 4 injector manifold
    Ohlins 3 way adjustable
    New tea tray / splitter tray last July
    Updated Rocker package
    Rebuilt steering rack July 2013
    Replay Over head video camera
    4 radios
    2 headsets
    Staubli quick disconnect fuel line, rear brake line and clutch line couplers
    Good set up notes
    Good engine manuals
    Good MOTEC guide
    MOTEC Timing Beacon
    New Beacon Battery
    Race Car cover
    SPARES
    All our engine spares / parts and electrical spares are new, no junk, no stuff that should have been tossed but wasn't
    New spares;
    New A arms for the complete car, with Aurora Gold PRM rod ends and sphericals installed
    2 New complete sets of brake rotors
    2 New sets of brake pads
    4 New mufflers
    1 New oil pressure relief valve
    1 New fuel pump
    1 New APV valve
    2 New Vacuum Valves
    New Tilton Slave rebuild kit
    1 New fan belt
    New injector seals
    New rad cap
    New vacuum lines
    New injectors
    New set / box of spark plugs
    New Spare Clutch assembly
    New spare oil lines
    New cartridge in line oil filter
    New Lambda Sensor
    2 New master cylinder / slave rebuild kits
    2 New MOTEC 100 MM linear damper sensors
    2 New axles
    New spare wood floor complete
    New tea tray splitter / Aluminum floor
    4 New carbon diffuser strakes
    New ATL Fuel Cell Replacement foam
    * I am told by the Pro Mazda Championship that the car will be allowed to run in the series with the following provision. All new Star Race Car parts and any Star engines will be inventoried and accounted for. When you retire a Star engine back to Speed Source for rebuild, you will then get a Speed Source sealed engine. With respect to suspension A Arms, those to will be accounted for and once you have used your Star parts you must replace with Pro Mazda Series identified parts. So in other words, you get to use the Star parts once, you can NOT replace Star parts with new Star parts.
    General Spares
    4 Spare coils (used. These were replaced as a part of annual maintenance)
    Spare carbon nose
    Spare shock cover
    Spare engine cover, older style quite heavy and has been repaired by previous owner
    Spare original style front wing assembly, complete with end plates, flaps, main plain
    Spare original style rear wing assembly complete. All this aero has fresh paint on it.
    Spare rear diffuser (2011 style)
    Spare pod tops (original body weight) all the spare bodywork has new paint, wet sanded to 3000, never installed on car since painted
    Spare original style air box
    2 KN air filters
    Spare clutch and plate
    One oil radiator / cooler
    One water radiator
    Spare aluminum cooling system tube
    MK 2 rockers
    Various pushrods for MK 1 and MK 2 rocker package
    FTR rear cover
    Spare 6 injector manifold (but it really isn't worth much)
    3/8" carbon wickers for front flaps
    2 Used metal diffuser strakes
    1 full size bead seat
    1 Lemans style seat insert for the seat above
    The car is great, runs well, does everything well. Problem is no one to race with in our region. We ramped up to race in the Pro series this year but when we lost the Indy race in Edmonton a ton of sponsorship dollars also vaporized!
    Three years ago it was painted, wet sanded to 3000 and it still looks pretty good. The tub is good, it does not have the S bend. we installed a new complete wood floor this year and it has only been tracked once this year so it is worn but still very good as well.
    We always change engine oil and filter every 800 miles or second race weekend, which usually include a dial day. Gear oil is never re used after a gear change, always new gear oil. Brake fluid is flushed one to two times per year depending on race frequency.
    I do have people interested in a rent a ride program for an FC so if you have a well prepared Zetec or a USF 2000 race car that has been loved and well cared for we would consider that in partial trade plus.
    Below is how the car looked this June, it has been tracked once this year, about 400 miles and still looks the same. We did change the 3, oil breather / return hoses in the engine compartment to a light weight, blue hose.
    In the pic attached, have a look at the edge that is where the engine cover and the tub meet. Since installing the new air-box this year, that lip has reduced quite a bit. The engine cover IMO still does not fit well but that's the way most are if they have the old style air box and with the new air box it fits better but still not perfect.
    The overhead engine shot is how the engine bay is now with the oil return lines changed to the lightweight hose and the new Air Box. Please forgive the dust on the car.
    People that have no interest in the car but do know well prepared race cars such as Keith Willis from Aim Autosport and Marty Knoll from MK Technologies have seen the car, worked on the car or engineered the car and Im sure will give you their opinion as to the level of preparedness and quality of the race car. Many others in the Pacific north west who also know cars have seen the car. So, if so inclined give them a call or shoot them an email.
    Also available for $2000 is a pit wall tire rack / parts storage / work bench /DAQ TAG cart.
    Thanks for your interest in the race car.
    Liked: 712
    Apexspeed still requires asking prices on all classified ads.
    Member Shane0's Avatar
    Chilliwack, B.C.
    If you sell will you join us in FB?
    Liked: 26
    Well Shane that may happen given that there are more fb's in the region but regardless if you go to Spokane next year we'll have our fb there running with you! .....
    Liked: 26
    Ok I think the ad includes most things I have for the car. At least anything of significance.
    BC Canada
    Default FB
    Are you going to keep the Stohr and race it next year.
    Desmond
    Liked: 26
    Yes, its looking that way D. At least there are some fb's within a 15 hour tow
    Senior Member RSS's Avatar
    Sylvan lake, Alberta
    Liked: 442
    Cough*FC*Cough
    Liked: 26
    If you are a pro effort or considering running in the Pro Mazda Championship I could break out just the car and a few other bits for a lower price. Would prefer to sell it as a package though.
    Liked: 26
    Deposit on car coming today. will advise if the deal goes south, thanks for the interest in this race car.
    Liked: 26
    Car is sold! Thanks APEX. Time for a contribution
    Contributing Member kflyer's Avatar
    Central, IL
    Congrats on the sale. Where's it headed? -K
    Kevin Davis
    04 Pro Mazda
    95 Lamborghini Diablo
    59 Piper Comanche
    Liked: 26
    Hi K, I was asked not to say just yet, I can say a pro team bought the car and it will be raced in the pro Mazda Championship next year. Cant say if they are new team or an established team but they are a pro effort.
    Sorry,
    B
    Central, IL
    Thanks. It'll be nice to see the series grow a little.
    Kevin Davis
    04 Pro Mazda
    59 Piper Comanche
