Results 1 to 10 of 10
Thread: Ball joint help
    Hoschton, GA
    Liked: 757
    Default Ball joint help
    Does anyone happen to know which road car these are sourced from? I believe they are triumph but haven't been able to ascertain the correct part number or a source. I believe they are common to most early FF's.
    Thanks!
    Memphis, TN, USA
    Liked: 416
    Start with eraly Spitfire or Herald. Very common to use those.
    Charlie Warner
    fatto gatto racing
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    If those are whitworth thread, you might try some of the Crossle suppliers. The 30 series uses them on the front end I believe.
    Winter Garden, Florida
    Liked: 160
    5/8-18 thread. Lee Chapman Racing has them. They are not cheap!!
    Cheers, Joe
    Senior Member BURKY's Avatar
    Florida
    Liked: 444
    Call Neil, at Porter racing...
    New Jersey
    You could also try Dave Bean Engineering.
    Liked: 919
    If you are not terribly worried about maintaining the period correct construction, I would respectfully suggest converting them to rod ends. Lathe and a drill press with a reamer would be all that it takes.
    Pick a size of rod end such that you can drill then ream the hole that the tapered pin currently resides in to fit.
    Then spin up new track rods of the appropriate length and internal threads.
    Much nicer set up and not as expensive to replace when they wear out (if they ever do ) again.
    Hoschton, GA
    Liked: 757
    Thanks for all the replies. I guess i was hoping they would be an off the shelf part, or at least readily available. I can find the female version all day long. Steve - the rod end conversion is a great idea, but I am going for a full period correct look for my sins!
    Senior Member rv greg's Avatar
    Puyallup,Wa.
    Hoschton, GA
    Liked: 757
    Ah ha! Excellent, thanks!
