I've pulled apart my LD200 to replace the output shaft seals. I'm also replacing the o-rings for the clutch slave. As long as I'm in there, what else should I check?
Second, what is the ideal lash for the R&P? Hewland specifies not less than 5 mils, but gives no maximum. I'm running about .007 right now.
Just curious, how long do most of you go between complete rebuilds? These boxes appear to be built incredibly stout and with the low HP we put through them I can't imagine them needing a rebuild often.
