I want to do a leak down test on my 07 GSXR 1000.
I have the leak down tester that I use on airplane engines and the adapter to fit the GSXR spark plug threads.
My question is how to hold the crankshaft so the piston stays at top dead center when air pressure is applied.
I could place a socket on thecrankshaft bolt under the cover on the right side of the engine.
On aircraft engines 80 PSI is used and anything over 60 PSI residual pressure is acceptable, but the closer to 80 residual the less leaking past the rings or valves.
Is a leak down test on our road bike engines a good indicator of ring and valve condition as it is on aircraft engines?
Any advice on procedure or validity of this test will be appreciated.
Thanks Herman 541 404 6464 Oregon
