Results 1 to 22 of 22
    Member racecarguy1968's Avatar
    Cincinnati, Ohio
    Default (WTB) ATL FC-152 Fuel Cell
    Hi
    I'm looking to buy a good used FC-152 ATL fuel cell. Or Fuel Safe CB304.
    Mine developed a small leak in the back seam. FC-152 is the only size that I think will fit and I can't find any other cell's that will be legal in both Vintage and SCCA.
    Please let me know what you have and the size if it's not an ATL FC-152 it can't be any wider than 14"
    I have an ATL 140, just a year old. Holds 4+ gallons.
    Mokena IL.
    Liked: 59
    Default Don't tease .....
    Come on Jay, don't tease us... How much for the ATL 140 ?
    ATL 140 fuel cell $350. 1 1/2 years old. No problems at all just too small for F600.
    Cincinnati, Ohio
    Default fuel cell
    Thanks But the 140 is way to big for mine, great price though. are ATL and Fuel safe the only ones that make cell's that are legal for SCCA? I see RCI cells online and they will fit better but not sure if they are legal.
    NC
    Liked: 304
    The RCI cells do not appear to be approved by any organization, so the answer is no. Also, they only list a 1, 3 and 4 gallon. The 1 is way too small, the 3 is questionable. The 4 gallon atl140 is as about as small as you can use. Fuel Safe has a similar 4 gallon unit that might be a better fit in some cases.
    You say it is way to big. But 4 gal is about the minimum. Maybe you mean the shape doesn't work? If so, custom will probably be your only option. More $$$.
    Senior Member Amon's Avatar
    Medina, Ohio
    Liked: 174
    What's the type of Vee you need a fuel cell for?
    Mark
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    I noticed on a couple of different sites, the FC152 had come down a little in price somewhere between $550 and $580. Still expensive however!
    Cincinnati, Ohio
    Default fuel cell
    Thanks for the website Nardi!! Great prices!
    http://carshopinc.com/
    Belvidere,Il
    Liked: 76
    see this site for standard cells. http://www.sracing.com/Store/Safety/fuel_cells.htm
    Reasonable prices on custom cells with FIA FT3 certification. call Butch for a quote.
    859-963-8318
    butch deer
    Senior Member SOseth's Avatar
    Hendersonville, TN
    Default Eagle Fuel Cell
    Check with Eagle. They have a website, can repair some cells and build legal new one's. They are much more reasonable than ATL and do a very nice job. I sent my cell to them and they copied exactly.
    SteveO
    Cincinnati, Ohio
    Default fuel cell
    Steve did you have to send Eagle a filler neck and fittings? they quoted me a good price but said I needed to supply the filler neck and outlet/vent fittings
    Lexington KY
    Liked: 50
    Quote Originally Posted by racecarguy1968 View Post
    That is correct. They build the cell only for your hardware.
    859-252-2349 or
    859-339-7425
    Hendersonville, TN
    I did not send them the hardware. They copied the mounts as they were in my old cell. When I recieved the cell I just installed my old hardware. They did however supply the gaskets.
    SteveO
    Senior Member SamF's Avatar
    Cincinnati Ohio
    Liked: 25
    Would you mind sharing that good price that you received from Eagle for the cell? Yesterday Eagle told me a FC152 clone without the metal parts would be $900. That is nearly 2 X the SR price and I would still need to find the metal bits.
    Sam
    Hendersonville, TN
    Default price
    Sam;
    I don't remember the exact amount but it was in the 950 range. Considering ATL wanted almost 1500 I chose least expensive route. My cell is a particular shape and size, no standard cell will work. If SR has what you need I would suggest going that route.
    SteveO
    Cincinnati Ohio
    Liked: 25
    [FONT=Calibri]Steve,[/FONT]
    [FONT=Calibri]Thanks, that is a very reasonable price for a custom made cell. I have worked with Eagle cells installed in aircraft and they have excellent quality. What I was curious about was the quote Sean received for the FC152 clone?[/FONT]
    [FONT=Calibri]Sam[/FONT]
    S. E. Michigan
    Liked: 113
    Bob Shedd and I developed a Lynx B cell with Eagle. It is slightly narrower than the 152 cell and slightly taller. It runs around $900. We went that way because the 152 interfered with the shift rod on our Lynx B. The shift rod location is different from car to car and the 152 cell will work on some Lynx B depending on how much you are willing to squeeze the cell into the can.
    When developing the car we knew the 152 cell would be questionable but we gave it a try.
    Bought a cell from Jim at SR at a very fair price -tried it out and could not make it work. Sold the new cell on apexspeed at an even more fair price.
    I was not exactly thrilled at spending $450 more for the Eagle but it was the right thing to do from a cell integrity standpoint.
    If you can get a standard cell to work there is no doubt it is a better route. For custom work Eagle tends to have the best response at reasonable prices. I have eagle cells in both of my FV and have had no issues.
    Mark Silverberg - SE Michigan
    Lynx B FV & Royale RP3 FF
    240Z Vintage Production Car
    PCR, Kosmic CRG & Birel karts
    Lexington KY
    Liked: 50
    We have ordered a cell from Eagle and have another one on order. Their cells are fine, but when you consider the price w/o hardware they are about the same as our Fuel Safe and ATL quotes. Plus their lead time is greater. They quoted us 3 to 4 weeks on our last cell and Fuel Safe and ATL are usually 7 to 10 working days.
    If you have good hardware, it is probably worth it. (Although ATL and Fuel Safe will also use your hardware if requested. )
    859-252-2349 or
    859-339-7425
    Cincinnati, Ohio
    Default fuel cell
    The Price they quoted me was for a custom cell it was $900 and using my old ATL hardware.
    Cincinnati, Ohio
    Default fuel Cell
    Well I went with the ATL 152 and bought it from Jim at SR Racing.
    If you ever need anything for FV's call SR Racing, great people to work with, fast service, and very helpful on FV questions.
    THANKS SR RACING!!!!
    Lexington KY
    Liked: 50
    Thanks for the nice words. BTW, Cell shipped, you should have it tomorrow.
    859-252-2349 or
    859-339-7425
