I wonder why we haven't seen an F-1000 car taking full advantage of the aero freedom. I mean, if I understand it right, you could nearly take a tube-frame D/SR car, remove a bit of fiberglass to make it "open-wheel" -- and you'd have one very efficient aero-car.
That is: Wide front body work surrounding the front wing (that stays at reg width)... nearly fully shrouded front wheels and tires (open at the top only and observing the body-width specs behind the back of the front wheel body work going to the outer edge of the tire in front) -- same in back (reversed) etc. And most importantly, a huuuge floor with an up-turned (reverse shovel) lip at the front (ahead of the rear of the front tire) -- to really pack some air under the car.
It seems you could make one very unusal looking beast that would minimize tire/wheel turbulence and generate huge amounts of underside negative pressure.
Is the only reason that no one's made "The Armadillo" (or whatever it'd be called) an aesthtically based decision? Are we more "stylists" than we are real edge-of-the-rules race car builders?
It seems it could all be pushed so much farther... Am I missing something?
Chris
