Rumor has it that several of the front runners we're running with shortboxes? Can anyone verify this and is it possible to run with the SB at RA?
Thanks!
Mark
Thanks!
Mark
I can't verify it but I know it has been done in the past at RA at the Sprints. You definitely can run a SB there, I have done it, but in the draft you will need to be able to pull some serious RPM.
Matt King
FV19 Citation XTC-41
CenDiv-Milwaukee
KEEP THE KINK!
SERIOUS RPM: 7000-7200 into Canada Corner if running with the front runners.
This is a questionable performance range with the new manifold rules.
Brian,
You probably would be due for a engine rebuild after those rpm's...even if the motor
did last the entire race.
Mark
Why? What would you anticipate needing service?
Mark,
The last time I heard of someone running a shortbox at Road America and being competitive was when C. Fred Clark won the June Sprints in 1980 (or there abouts) when a hot lap was in the 2:55 range. With a longbox and a draft, it is easy to be north of 6800 RPM. This was a few years ago when a quick time was around 2:44. Nuby cranks off a 2:41.4 yesterday...... I have doubts on a shortbox at RA
Bill Bonow
