Results 1 to 19 of 19
    New Milford, CT
    Liked: 17
    Default Aluminum Alloy for Wing plates
    Does anyone know what alloy or what specific aluminum I can make my front wing end plates for a 98 Van Diemen? Thanks
    Chris
    Default Alloy Al plates are
    of different alloys available. The end plates are NOT a structural part unlike the support plates. The important issue is plate thickness and for end plates I would use .080"-.090" any aluminum alloy that you can get: 6061T6, 2024T3...etc.
    New Milford, CT
    Liked: 17
    Thank you for the response.
    CM
    San Jose, Ca
    .060 aluminum, any alloy and hardness is fine. I've made structural wing supports from .060 6061 T6, and while they needed some support worked fine for years, so for a non-structural panel or endplate its probably overkill.
    Senior Member Becker Motorsports's Avatar
    redondo beach, calif.
    I used .093 6061-T6, for front and rear end plates with no problems. allthough I use Guy wires on the rear endplates to prevent any possibility of flexing.
    Somerset, Kentucky
    Liked: 126
    I use balsa wood, S-glass, and epoxy!
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    I use G-10 sheets (already black) from McMaster.
    http://www.mcmaster.com/#grade-g-10-...-stock/=c7l6yc
    Liked: 927
    to r4eally save weight go to the local plastics store and get some drops of HDPE sheet.
    Will cost like nothing if they have any and weigh even less
    Liked: 291
    RobLav
    What thickness balsa and what general finished thickness? Do you have a mold for both sides of a given end plate?
    Sarver, Pa
    I use .060 alum T-6. BUT, i like the idea of the G-10. Bob, is it paintable ?
    Jupiter, Florida
    Liked: 79
    It should be as we did an experiment at work where we had some .25 thk panels and we painted one side with marine type epoxy paint. I liked it because It did not have to paint it to use for my front wing end plate. I may even make a dash with it.
    But be aware that I ad to use a abrasive tyoe of jig saw blade to cut it.
    If you are going to paint it anyway, they also have green fiberglass sheets:
    http://www.mcmaster.com/#fiberglass-...sheets/=c8581h
    ASRF1000
    Guest
    Monte, How much area (dimensions) do you have to play with as far as overall front wing width. Do your end plates have to be flat?
    ASRF1000
    Guest
    Monte,
    I have a set of light weight aluminum end fences we made up for our F1000 if they can be of use to you. See pics.
    Somerset, Kentucky
    Liked: 126
    That 1/4" thick HPDE sounds like a pretty good thing. Much faster than epoxy.
    Brian - I've used 1/4" balsa sanded a bit in the belt sander. The balsa needs a coat of epoxy on both sides to harden before using the glass, otherwise the epoxy will soak in the wood and you won't get a good bond. No molds - just cut to what I want to produce - and I use an old greasy shower curtain as the non-stick.
    New Milford, CT
    Liked: 17
    Default endplates
    My endplates are flat with the Whizzy Bits on the side adding 2 inches on each side in total wing width. I have the moustache wings on a 98 Van Diemen
    Bethel CT
    That's a nice car mister.
    New Milford, CT
    Liked: 17
    Ah, Thanks monte442. Its got a sweet motor. Tons of work done by me and my Bro to get it done. He does great work.
    ASRF1000
    Guest
    Monte,
    The endplates I have (as shown in above post) are 2 " wide.
    Danbury, CT.
    Liked: 1908
    Quote Originally Posted by monte442 View Post
    All it needs is a Stonebridge sticker !
