[SIZE=4]I am selling my most recent purchase. It is a 2008 RSV1000R that has been laid down on the left side. There is no major damage to the engine or chassis from what I can find. This engine and ecu system would be a perfect candidate for your V-Twin powered sports racer. Bike runs fine no issues ! 4000.00 OBO !!!
[/SIZE]
Displacement: 997.62 ccm (60.87 cubic inches)
Engine type: V2, four-strokePower:141.12 HP (103.0 kW)) @ 10000RPM
Torque: 57.00 Nm (5.8 kgf-m or 42.0 ft.lbs) @ 8000 RPM
Compression:11.8:1
Bore x stroke: 97.0 x 67.5 mm (3.8 x 2.7 inches)
Valves per cylinder: 4
Fuel system: Injection. Integrated electronic engine management system. Indirect multipoint electronic injection. 57 mm throttle bodies.
Fuel control:DOHC
Ignition:Digital electronic ignition, with one spark plug per cylinder, integrated with fuel injection system.
Lubrication system: dry sump with separate oil tank.
Cooling system:Liquid Cooled Electronic Fan
Gearbox:6-speedTransmission type,
final drive:Chain
Clutch:Multi-plate clutch in oil bath with patented PPC power-assisted hydraulic control.
rowch01@gmail.com
Thanks !
