Looking for a stock harness with the rectifier - ECM is optional
Mike,
I've got a spare harness with rectifier. Make an offer with or without ECU.
Sent email but not sure if it went through.
Tom
I know that I'm reading things into your desire for a harness and specifically a rectifier BUT I have found that if I don't run a separate ground wire from the rectifier ground right to the negative post of the battery I end up prematurely losing the rectifier (and sometimes some wiring). Grounding the rectifier ground to a good firm, clean section of the frame should be enough but electricity sometimes has a mind of its own.
Hasty Horn
Hasty - have you found that rectifiers get really hot (unless mounted in a fresh airstream)?
Clark
It seems to me that to get the most life out of a rectifier it should be kept cool.
I am not 100% certain about the inner workings, but I am pretty sure that the diodes in the rectifier lose efficiency as their operating temperature rises. Basically, if the rectifier is cool then it will do a better job of turning horse power into electricity rather than converting it into heat.
