    Liked: 123
    Default engine bay floor stressed panel??
    If I add a floor to the engine bay portion of the chassis on my car (full chassis all the way back, not a bolt on piece) can it be "stressed" ie glued on and rivited every inch, or must it be unstressed - rivited every 6 "?
    The floor rule requires a stressed panel only back to the roll bar bulkhead. I'm unsure about the floor behind the bulkhead.
    Thanks, Brian
    Senior Member JByers's Avatar
    Livonia, MI
    Liked: 24
    Thanks, Brian
    Brian, It's not a problem to glue and rivit a full length pan unless you deviate from the 1" rule. A problem that I developed when I ran a full pan was the through bolts at the bottom of the bell housing started to sheer.
    Liked: 303
    Default Change the oil
    I thought of doing the same thing to the Bowman but the hassle it would be to drain the oil from the oil pan prevented me from doing it.
    Ed
    Tacoma, Washington
    Liked: 210
