We've been working hard on building the prototype 2008 car, but are also finishing up some work on the computer. I thought I'd post the latest renderings:
These pictures effectively show one of the aspects of the new car we're most proud of- overall packaging! The body is, in our opinion, as narrow as an F1000 car can get and remain practical. The rear shot is a good example of this- you can see the bulges in the bodywork on either side, to allow clearance for the sprocket and engine on the left and right sides, respectively. The sidepods are also quite low, to further reduce the overall frontal area of the car.
The end result of all this "trimming" is the smallest possible frontal area, with the associated reduction in drag. This should substantially increase the F1K-08 car's top speed and acceleration. The low sidepods will help provide cleaner air to the rear wing.
Also noteworthy are the chimneys and louvers on the rear of the sidepods. These will evacuate air from our heat exchangers, increasing their efficiency. Not visible are our integrated cooling ducts. These are built into the bodywork of the center section of the car, and serve to tightly seal our heat exchangers within their ductwork. Proper ducting of incoming air and evacuation of outgoing air allow us to run smaller heat exchangers and sidepods, reducing weight, frontal area, etc...
Expect some more images in the near future, as we continue to run CFD testing on our bodywork and wing package.
