Results 1 to 6 of 6
    Senior Member oh2winindy's Avatar
    SC
    Default Square intake hole filled in?
    On the intake for the carb, between the 4 round holes is a small sqare to oval shaped hole that matches the same hole on the head. On the used one I got last year, that hole is filled in with some kind of buildup??????
    On the old one I have, it is not. What is the hole for, and is it supposed to be filled?
    Am I like stu and pid?
    Jamie Cole
    89 Reynard CFC
    Only those who risk going too far will ever know how far to go
    http://www.kintera.org/grassroots/jamieracesforlaf/
    Paso Robles, CA
    Liked: 286
    I believe that is the water jacket used on a street engine, to help warm the engine faster. For performance we want the intake manifold as cool as possible, so this is typically blocked at the head with the gasket, and may be filled in on the intake manifold.
    I would ask your engine builder for his recommendation.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    SC
    Thanks David,
    Definetly looks like a cooling port of somekind.
    Jamie Cole
    89 Reynard CFC
    Liked: 3787
    Cut a small piece of thin brass shim stock and glue it over the hole (against the head) with red high heat RTV before you install the gasket.
    SC
    Thanks my honorable reptilian friend... see ya soon!!!!!!!!!!!
    Jamie Cole
    89 Reynard CFC
    Member frankwissman's Avatar
    Belmont, CA
    I had mine welded shut and ground flush. A tiny bit more weight and one less place I can't forget to add sealant.
