Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 81 to 120 of 429
  1. #81
    Morton, Illinois
    Default Irp
    Anyone have gearing for IRP on a 10:31 RP...Thanks Todd
  2. #82
    Senior Member thunderracing91's Avatar
    WI
    Anybody know the gearing for Mid America Motorplex? I have a 9:31 RP with hoosiers. Also has anybody figured out the gearing for the new Heartland Park runoffs course? I plan on running some nationals the end of july.............
    Thanks!!
    Andrew
    thunder racing
  3. #83
    Fresno,CA
    Default Heartland Park Gearing
    Since a couple of races have now been run on the "Runoffs configuration", does anyone have available the gearing for a FF with a 9:31 ring and pinion?(I can convert the gearing from a 10:31 ring and pinion)
    JMB
  4. #84
    locust valley, ny USA
    Liked: 142
    i'd be interested in the FC gearing too
  5. #85
    WI
    Nobody has any gearing info on the new heartland park runoffs configuration? Well does anybody have any gearing info for the milwaukee mile? (or somthing similar to another track that would work for the milwaukee mile?)
    Thanks!!!
    Andrew
  6. #86
    Morton, Illinois
    Default Road America
    Can someone give me gears for FF with a 10:31 RP for RA,,,Thanks Todd
  7. #87
    Maineville
    Liked: 103
    Default Mid-Ohio FF Gearing
    Can anyone provide gearing for a 9:31 R&P Formula Ford Gearing for Mid-Ohio?
  8. #88
    New York
    Liked: 157
    Default Watkins Glen Long and Short Course
    I saw the earlier posts on this thread with suggested gearing for the WG long course, but there is quite a bit of difference of opinion between the gearing listed in the two posts. We plan on going to the double regional in September, which is long course on Saturday and short course on Sunday. Would appreciate it if someone would share their gearing for the two courses, we are running a 10:31 R&P.
    Tom Valet
  9. #89
    New Jersey
    I THINK the difference you're seeing is because of differing ring & pinion ratios. The first post is for a 10:31 set, and the more recent post is probably for a 9:31, although it's not specified. If you do the conversion, they are actually the same overall ratios.
    New York
    Liked: 157
    Steve, thanks for clearing that up.
    Do you happen to know whether the gearing for the Glen short and long courses is the same?
    Tom
  11. #91
    New Jersey
    Well, I may not be the best person to ask. I've only run the Glen once, and I ran my Summit gearing because I don't have the extra gearsets yet ($$$). But, to my thinking the gearing would be the same, you just won't use 1st gear on the short course.(see Shep's list of which gear for each turn)
    New York
    Liked: 157
    Default Pocono North Gears
    Thanks Steve.
    Next gearing I need is for Pocono North, the 1.5 mile course, FF with 10:31 R&P. Anyone know?
    Tom
  13. #93
    New Jersey
    Default Pocono Gearing
    No one seems to have any recommendations on Pocono gearing. There is a large difference between the ratios in Jake's book, 17:34, 20:31, 23:29, 26:26 and the Summit gears JD runs, 19:31, 21:29, 23:27, 25:25. I'm concerned that 2nd, and especially 1st, may be too low, even though there are two very slow turns. Has anyone tried similar ratios? Thanks,
    New York
    Liked: 157
    Steve,
    After putting up that last post in August about Pocono and not getting any response, a friend suggested that for the North Course we should use our Lime Rock gears, which is what we did when we went there in September. I will double check with my son, who drove the car, but I dont believe he used 1st gear in any of the corners. The LR gearing was very close and since there was only one other FF there at that event, we didnt play around with any gear changes. Maybe a tooth up or down might have made a difference, maybe not.
    HTH
    Tom Valet
    FF #10
    Swift DB-1
  15. #95
    New Jersey
    Tom,
    Thanks, I should have been more specific. I'll be running the long course SCCA uses for Regionals, using NASCAR turn 3 and the tunnel turn. I use 1st where you re-enter the oval heading towards the tunnel, and in the chicane before T-3.
    Contributing Member Joe911's Avatar
    Gainesville FL
    Default Moroso
    Needing gearing recommendations for the current Moroso for FF. I run a 10/31 but I can convert if you have gearing for a 9/31.
  17. #97
    Gainesville FL
    Default Homestead
    I don't have much luck getting gear advice - but here goes... using 10/31 diff ...
    Homestead National course (using banked turns 3 & 4)? I mostly need top gear as I have run the other course at a regional.
  18. #98
    Fredericton N.B. Canada
    Default need to know gear ratios for NHIS,WATKINSGLENN,MONT TREMBLANT,MOSPORT
    I have a 10:31 ring and pinion and would like to know the gear ratios for NHIS,WATKINS GLENN, Mont Tremblant and Mosport for a Formula Ford .Any help would be greatly appreciated.
    Thank You
    TIM
  19. #99
    Portland, Or.
    Default DB6 gears
    Anyone want to share information for the gearing of a DB6 FF on Goodyears with 10:31 ring and pinion at the following tracks?
    PIR (Portland) - both layouts:
    Seattle:
    Thunderhill:
    Trying to figure the gearing out using information from a Crossle CF on American Racers and 9:31 R&P to the above car is making my head hurt!
  20. #100
    Senior Member pcarnut's Avatar
    NC
    Default Gears for Rockingham (The Rock)
    Anyone out there know what gears to run at Rockingham, NC in FF with 9:31??
    Mucho thanks.
  21. #101
    Senior Member cliff's Avatar
    kansas city, MO
    Liked: 72
    anyone want to share gearing for TWS, 2.9 mile course.
    Please list which R & P you are referencing. Thanks
  22. #102
    Senior Member Whoomah's Avatar
    Rockwall TX
    Quote Originally Posted by cliff View Post
    This is in the baseline gearing file for a 10:31
    Texas World Speedway (2.9 config.) 18/33, 20/30, 23/29, 24/26
    http://www.apexspeed.com/resources/baseline_gearing.htm
    Curt
    Curt King
    Rockwall TX
  23. #103
    Member fv03's Avatar
    Roanoke Va.
    Default VIR gearing
    FF with 9:31 What gears? Full course. Thanks ,Tom Guthrie
  24. #104
    New York
    Liked: 157
    Default Pocono National Course
    This has been asked before by others, but I dont think anyone posted any recommendations. Looking for gearing for the Pocono "National" track (full course, clockwise, with the bus stop on the backstraight), Mk 9 in an FF with 10/31 R&P.
    Tom
    FF #10
    Swift DB-1
  25. #105
    Contributing Member Tim Webb's Avatar
    Fayetteville, AR
    Default Gears MAM
    Anyone?
  26. #106
    Kansas City
    Liked: 110
    Default Memphis
    Anyone have Memphis gears for a 10/31?
  27. #107
    Santa Cruz, CA
    Liked: 23
    Would anyone out there be willing to share gearing for Mont Tremblant? 9:31 or 10:31, I can do the math.
    Thanks in advance.
    Tim
    'Stay Hungry'
    JK 1964-1996 #25
  28. #108
    Contributing Member AFBENSON's Avatar
    FLORIDA
    Default Barber Msp
    Has anyone run Barber? and figured out the gearing.
  29. #109
    Orlando Florida 32812
    Liked: 605
    Default Barber gearing?
    FF 9/31 R&P - anyone suggest what to use at Barber? maybe about the same thing as Sebring short?
  30. #110
    Liked: 605
    all i can find so far after about two hours on line searching, rather than a gear recommendation, is a quote from Dorsey Schrader about Barber > "it's a point and squirt track" - so gearing would be sort of low to guess. i promise to eventually post something about Barber in the > perpetual what gearing do i run? thread
    BARBER - here are some notes - thank you your purpleness
    remember these numbers were a 10/31 FC
    17/33 17/28 21/29 24/28
    or
    18/33 20/30 22/29 24/27
    july 10th
    after going there.........
    CF 9/31 diff. used 1st 17/35....would go a little taller but i didn't have the gear, a lot of people going around asking "have you got a 18/33 i could borrow?"
    2nd 20/32...i think gaither ran the 21/30 that i loaned him
    3rd 22/29 4th 24/28. maybe you could do it but i looped it in the kink trying to take it in 4th flat out.
  31. #111
    Member vancourt's Avatar
    Michigan
    Default Gingerman Gears
    Looking for Gingerman gears with
    9:31 R & P & Goodyears
  32. #112
    Michigan
    Default Mid-ohio Gearing
    Does anyone have the gearing for Mid-Ohio. 9:31 R&P
  33. #113
    North Eastern NJ
    Default Is this a reasonable WG Long Gear Compromise
    We have a limited MK-5 Gear selection and are not going to make an investment in any more right now. For WG Long (W/Inner Loop), does this sound reasonable?
    FC 2000 Citation - Pinto SHIFT RPM = 6800 -
    10/31 R&P, Mid life Engine, High Downforce wings trimmed out
    1st 16/26 Ratio 1.625 - MPH @6800 88.4
    2nd 21/30 Ratio 1.429 - MPH @6800 100.5 - RPM DROP 822 - RPM 5978
    3rd 21/26 Ratio 1.238 - MPH @6800 116.0 - RPM DROP 907 - RPM 5893
    4th 19/21 Ratio 1.105 - MPH @6800 129.9 - RPM DROP 730 - RPM 6070
  34. #114
    Liked: 3787
    I'm thinking your math is wrong.
    I show that a 19/21 would turn 133.49 mph at 6800 with a tire 22.6" in diameter.
    If your math is correct, I think 129 is too slow for WGI (long). I'm thinking you might want to be in the 135 - 140 top end range...
    I don't know anything, so this is worth less than 2 cents. A experienced NE guy needs to chime in.
  35. #115
    North Eastern NJ
    The differance between your 133.49 and my 129.9, is you using 22.6" for tire diameter and me using 22". Next time I get the tape measure out, I'll double check the size (I have to anyway, since I'm switching from the GY to the Hankook Radials for this event. That's the tallest gear I have for now so it will have to do. If I run out of revs. I run out out revs. I have a couple options on 1st, 2nd, 3rd.
  36. #116
    Murrysville Pa.
    Default VIR Fulll Course Gearing
    Anyone have any suggestions on gearing for VIR full course with a 10:31 with GY160's? Neever been to VIR but I am going there at the end of October and would appreciate any help I can get
  37. #117
    Elkhart Lake, Wisconsin
    Default Road Atlanta
    looking for Road Atlanta gearing. Please reference which ring and pinion you are using.
    thanks
  38. #118
    Contributing Member R John Lye's Avatar
    Palmyra, VA
    Default VIR gearing
    Quote Originally Posted by Bob Lutz DB-1 #54 View Post
    Hi Bob,
    This is the gearing that Curtis Boggs posted for VIR:
    (and Summit Point):
    18:32 or 18:33
    20:30
    23:29
    24:26
    I hope to be there also, so I'll look for you.
    John
  39. #119
    Danbury, CT.
    Liked: 1908
    Default Homestead anybody ?
    Anybody got any ideas for someone that has never seen the place?
    F/F 1600 10/31 or 9/31 I can do the math.
    Thanks, Agnif
  40. #120
    St Cloud, Fl
    Liked: 136
    Default homestead
    10-31
    17-34
    20-31
    22-28
    25-27
    John
