Results 1 to 8 of 8
Thread: TIGA FF Axles
    Texas
    Default TIGA FF Axles
    Hello to all,
    1977 TIGA FF - broke a half shaft/axle. It has the old original style CV joints. I see pictures of TIGA's converted to modern CV joints but so far, no clear path on what is involved, process and parts involved.
    Any solid suggestions would be very much appreciated.
    Memphis, TN, USA
    Liked: 416
    Quote Originally Posted by Jbird57 View Post
    Hello to all,
    If by "old original style" CV joints you mean straight-plunge 23 spline axles, you are out of luck. Easy fix. 4 new 33 spline fluted CV joints (call Scotty Young) and have 2 new axles made. There are quite few outfits in CA that supply the off road crowd that can make axles any length you need for reasonable cost (unless you want them gun-drilled.)
    Charlie Warner
    fatto gatto racing
    Maple Grove, Minnesota
    Default Tiga axles
    I have a 1980 Tiga FFA that Craig Taylor, who has since retired, converted to a formula mazda axle system. Scott Young worked with him and would be who I'd also recommend you contact.
    San Jose, Ca
    Liked: 94
    Taylor also makes axles.
    Member tiga57's Avatar
    milwaukee
    Liked: 12
    Default Tiga
    If you want to go all in you could have these guys make new uprights with any bearing dims needed to accomplish a best-to-you solution. I put a set of the front uprights on my S2.
    https://sports2000racing.com/pages/p...ca12be60&_ss=r
    I know they have 78' and newer, not sure if 77' is same though looks like a 77' in photo.
  9. #6
    Texas
    Quote Originally Posted by tiga57 View Post
    Wow those are nice! Any idea how much they were?
    milwaukee
    Liked: 12
    Ballpark was about 2k for the fronts, so assume a bit more $ for the larger rears, and I had some custom work done for rotor/hat upgrade. Really nice, they digitally scan the OE parts and replicate the critical dims for the billet parts. I vapor blasted them to take the tool marks and shine off and they look the part on my S2....some added piece of mind really, 1980 was a long time ago!
    info@sports2000racing.com
    Quote Originally Posted by mphand View Post
    I second Scotty!!!!1
