    Member jcolley's Avatar
    Portland, Maine
    Default Replacement PFC Rotors
    Going through my car and have one rotor that measures slightly tweaked, causing some drag.
    PFC Rotors 255.10.0042.03 and .04, Pegasus says no longer made.
    Any alternative rotors compatible with the PFC calipers?
    Portland, Maine
    Nevermind, they appear to match dimensions of LD20 discs.
    Yes, but the PFC 2 groove floating disc we use on FCs w/LD20s is no longer made either.
    Liked: 1878
    If you cannot find them elsewhere, I should be able to make them for you.
    Liked: 1878
    I'll be receiving a sample rotor in the next few days to make a drawing from, so if anyone needs replacement rotors, I'll be able to make them quickly.
    Portland, Maine
    I'm likely in for a set of 4.
    Liked: 1878
    I'll post again once I have a drawing ( and check my stock of blanks, of course!).
