Going through my car and have one rotor that measures slightly tweaked, causing some drag.
PFC Rotors 255.10.0042.03 and .04, Pegasus says no longer made.
Any alternative rotors compatible with the PFC calipers?
Nevermind, they appear to match dimensions of LD20 discs.
Yes, but the PFC 2 groove floating disc we use on FCs w/LD20s is no longer made either.
If you cannot find them elsewhere, I should be able to make them for you.
I'll be receiving a sample rotor in the next few days to make a drawing from, so if anyone needs replacement rotors, I'll be able to make them quickly.
I'll post again once I have a drawing ( and check my stock of blanks, of course!).
Have the PFC rotors, and have made the drawings. Price should end up somewhere right around $200 each. I'm hoping to do decent sized batch so that the raw material cost can come down a bit.
If anyone is interested, message me.
You can have them either way - if face grooved, they will be handed. Not grooved = not handed. $25 extra for the grooving.
Will hopefully get a quote for a batch of blanks come Monday or Tuesday.
