    San Jose Ca
    Liked: 80
    Default coolant plug? Why
    Hello All,
    I have a question about a coolant plug in the front of the engine, so if your looking to the front of the engine and near the left front head bolt came with a threaded plug that went into the blocks water jacket? Does anyone know why this is here or does it need it. On a side note the head had rusty water/coolant were the block did not? Not sure why, working on pic's.
    Ben
    Paso Robles, CA
    Liked: 285
    I've seen plenty of water temp sensors mounted in that location.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Liked: 945
    Quote Originally Posted by CM/FFdriver View Post
    Hello All,
    Ben
    Ben, do you mean the 1/8" NPT just below the thermostat housing? That's where Ford put the original temperature switch and where most of us put the temp sender.
    San Diego,Ca
    Liked: 491
    Default plug
    Is this plug in the side of the head or in the front of the block?
    Roland Johnson
    San Diego, Ca
